Deepstream freezing issue
I just ran the deepstream-test1-usbcam application. After sometimes may be 15 or 30 mins, the stream freezes in Jetson AGX Orin - Jetpack 6.2 [L4T 36.4.3]. I will paste the error below. Even I debugged with the help of chatgpt. No use. Still freezes after sometimes. Below is the error.
Frame Number=17254 Number of Objects=2 Vehicle_count=0 Person_count=2
Frame Number=17255 Number of Objects=3 Vehicle_count=0 Person_count=3
Frame Number=17256 Number of Objects=2 Vehicle_count=0 Person_count=2
Frame Number=17257 Number of Objects=3 Vehicle_count=0 Person_count=3
Frame Number=17258 Number of Objects=3 Vehicle_count=0 Person_count=3
Frame Number=17259 Number of Objects=2 Vehicle_count=0 Person_count=2
Frame Number=17260 Number of Objects=4 Vehicle_count=0 Person_count=4
/dvs/git/dirty/git-master_linux/nvutils/nvbufsurftransform/nvbufsurftransform_copy.cpp:341: => Failed in mem copy
ERROR: Failed to make stream wait on event, cuda err_no:700, err_str:cudaErrorIllegalAddress
ERROR: Preprocessor transform input data failed., nvinfer error:NVDSINFER_CUDA_ERROR
0:11:50.054030505 6688 0xaaaabe8fc8c0 WARN nvinfer gstnvinfer.cpp:1420:gst_nvinfer_input_queue_loop: error: Failed to queue input batch for inferencing
Frame Number=17261 Number of Objects=0 Vehicle_count=0 Person_count=0
Error: gst-stream-error-quark: Failed to queue input batch for inferencing (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1420): gst_nvinfer_input_queue_loop (): /GstPipeline:pipeline0/GstNvInfer:primary-inference
libnvosd (1386):(ERROR) : cuGraphicsEGLRegisterImage failed : 700
0:11:50.055893056 6688 0xaaaabe8fc980 WARN nvinfer gstnvinfer.cpp:2423:gst_nvinfer_output_loop: error: Internal data stream error.
0:11:50.055917344 6688 0xaaaabe8fc980 WARN nvinfer gstnvinfer.cpp:2423:gst_nvinfer_output_loop: error: streaming stopped, reason error (-5)
CUDA Runtime error cudaFreeHost(host_) # an illegal memory access was encountered, code = cudaErrorIllegalAddress [ 700 ] in file /dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvll_osd/memory.hpp:78
CUDA Runtime error cudaFree(device_) # an illegal memory access was encountered, code = cudaErrorIllegalAddress [ 700 ] in file /dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvll_osd/memory.hpp:79
nvidia@ubuntu:/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-test1-usbcam$
Can you try to set copy-hw=2 property of nvvideoconvert ? It seem a known issue in JP-6.2
