I run Ubuntu 20.04 with RTX3090. I get bunch of warnings and couple of errors when trying to start the graph composer. I’m not a Linux person so it’s hard for me to decode some of those but the main symptom is: I get the composer UI but without any actual nodes available - I guess that’s what the failed get repo error means…
That’s what I get in the terminal:
mike@greedo:~$ composer
./kit/kit ./composer/composer-standalone.kit --ext-folder composer --allow-root
Loading user config located at: ‘/home/mike/.local/share/ov/data/Kit/composer-standalone/3.0/user.config.json’
[Info] [carb] Logging to file: /home/mike/.nvidia-omniverse/logs/Kit/composer-standalone/3.0/kit_20230921_202143.log
2023-09-21 19:21:43 [1ms] [Warning] [omni.ext.plugin] [ext: omni_kit] Extensions config ‘extension.toml’ doesn’t exist ‘/tmp/.tmpNvXgRaphComposer/run/composer/omni_kit’ or ‘/tmp/.tmpNvXgRaphComposer/run/composer/omni_kit/config’
mike@greedo:~$ [0.085s] [ext: omni.stats-0.0.0] startup
[0.091s] [ext: omni.rtx.shadercache-1.0.0] startup
[0.094s] [ext: omni.assets.plugins-0.0.0] startup
[0.095s] [ext: omni.gpu_foundation-0.0.0] startup
2023-09-21 19:21:43 [91ms] [Warning] [carb] [Plugin: libcarb.blockcompression.plugin.so] Could not locate the function: carbGetFrameworkVersion
2023-09-21 19:21:43 [91ms] [Warning] [carb] Potential plugin preload failed: /tmp/.tmpNvXgRaphComposer/run/kit/extscore/omni.gpu_foundation/bin/deps/libcarb.blockcompression.plugin.so
2023-09-21 19:21:43 [91ms] [Error] [omni.ext.plugin] [ext: omni.gpu_foundation-0.0.0] failed to load native plugin: /tmp/.tmpNvXgRaphComposer/run/kit/extscore/omni.gpu_foundation/bin/deps/libcarb.blockcompression.plugin.so
[0.100s] [ext: carb.windowing.plugins-1.0.0] startup
[0.106s] [ext: omni.kit.renderer.init-0.0.0] startup
| Driver Version: 535.113.01 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce RTX 3090 | Yes: 0 | | 24576 MB | 10de | 0 |
| | | | | | 2204 | 4aefb1ac… |
| OS: Linux greedo, Version: 5.15.0-67-generic
| Processor: Intel(R) Core™ i7-9700F CPU @ 3.00GHz | Cores: Unknown | Logical: 8
| Total Memory (MB): 64223 | Free Memory: 61438
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
[0.260s] [ext: omni.kit.pipapi-0.0.0] startup
[0.262s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.265s] [ext: omni.usd.config-1.0.0] startup
[0.269s] [ext: omni.usd.libs-1.0.0] startup
[0.396s] [ext: omni.kit.loop-default-0.1.1] startup
[0.396s] [ext: omni.kit.async_engine-0.0.0] startup
[0.397s] [ext: omni.kit.test-0.0.0] startup
[0.429s] [ext: omni.client-0.1.1] startup
[0.435s] [ext: omni.appwindow-1.0.1] startup
[0.438s] [ext: omni.kit.renderer.core-0.0.0] startup
[0.510s] [ext: omni.kit.renderer.capture-0.0.0] startup
[0.512s] [ext: omni.kit.renderer.imgui-0.0.0] startup
[0.577s] [ext: carb.audio-0.1.0] startup
[0.599s] [ext: omni.ui-2.14.4] startup
[0.607s] [ext: omni.uiaudio-1.0.0] startup
[0.608s] [ext: omni.kit.mainwindow-1.0.0] startup
[0.609s] [ext: omni.kit.uiapp-0.0.0] startup
[0.609s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[0.628s] [ext: omni.usd.schema.anim-0.0.0] startup
[0.670s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[0.675s] [ext: omni.usd.schema.audio-0.0.0] startup
[0.678s] [ext: omni.usd.schema.semantics-0.0.0] startup
[0.681s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[0.684s] [ext: omni.usd.schema.physics-0.0.0] startup
[0.690s] [ext: omni.usd.core-1.0.4] startup
[0.692s] [ext: omni.gpucompute.plugins-0.0.0] startup
[0.692s] [ext: omni.timeline-1.0.5] startup
[0.694s] [ext: omni.kit.audiodeviceenum-1.0.0] startup
[0.694s] [ext: omni.hydra.usdrt_delegate-4.3.11] startup
2023-09-21 19:21:44 [693ms] [Warning] [carb] [Plugin: libusdrt.hydra.scene_delegate.plugin.so] Module /tmp/.tmpNvXgRaphComposer/run/kit/extscore/omni.hydra.usdrt_delegate/bin/libusdrt.hydra.scene_delegate.plugin.so remained loaded after unload request
[0.706s] [ext: omni.kit.window.popup_dialog-2.0.16] startup
[0.710s] [ext: omni.kit.actions.core-1.0.0] startup
[0.711s] [ext: omni.kit.widget.nucleus_connector-1.0.3] startup
[0.713s] [ext: omni.kit.commands-1.4.5] startup
[0.716s] [ext: omni.hydra.scene_delegate-0.3.0] startup
[0.721s] [ext: omni.usd-1.7.0] startup
[0.757s] [ext: omni.kit.widget.path_field-2.0.4] startup
[0.758s] [ext: omni.kit.collaboration.channel_manager-1.0.11] startup
[0.759s] [ext: omni.kit.menu.utils-1.4.7] startup
[0.766s] [ext: omni.kit.widget.browser_bar-2.0.5] startup
[0.766s] [ext: omni.kit.usd.layers-2.0.14] startup
[0.773s] [ext: omni.kit.window.console-0.2.3] startup
[0.780s] [ext: omni.kit.widget.filebrowser-2.3.10] startup
[0.788s] [ext: omni.iray.libs-0.0.0] startup
[0.791s] [ext: omni.kit.widget.versioning-1.3.8] startup
[0.793s] [ext: omni.kit.search_core-1.0.2] startup
[0.793s] [ext: omni.kit.notification_manager-1.0.5] startup
[0.796s] [ext: omni.mdl.neuraylib-0.1.0] startup
[0.797s] [ext: omni.kit.window.filepicker-2.7.16] startup
[0.829s] [ext: omni.kit.widget.graph-1.5.6-104_2] startup
[0.841s] [ext: omni.mdl-0.1.0] startup
[0.856s] [ext: omni.kit.window.file_importer-1.0.10] startup
[0.857s] [ext: omni.kit.graph.delegate.modern-1.6.5] startup
[0.859s] [ext: omni.kit.material.library-1.3.21] startup
[0.863s] [ext: omni.kit.clipboard-1.0.0] startup
[0.864s] [ext: omni.kit.documentation.builder-1.0.9] startup
[0.868s] [ext: omni.kit.context_menu-1.5.12] startup
[0.871s] [ext: omni.kit.graph.delegate.default-1.0.18] startup
[0.871s] [ext: omni.kit.widget.searchfield-1.1.0] startup
[0.872s] [ext: omni.kit.window.property-1.8.2] startup
[0.874s] [ext: omni.kit.window.title-1.1.2] startup
[0.874s] [ext: omni.kit.widget.prompt-1.0.5] startup
[0.875s] [ext: omni.kit.graph.editor.core-1.5.1] startup
[0.877s] [ext: omni.kit.widget.settings-1.0.1] startup
[0.878s] [ext: omni.exp.graph.core-1.5.2] startup
[0.882s] [ext: omni.exp.graph.composer-3.0.0] startup
[0.926s] [ext: composer-standalone-3.0.0] startup
[1.296s] app ready
2023-09-21 19:21:45 [1,543ms] [Error] [omni.exp.graph.composer.registry_window] Failed to get repo list: <AioRpcError of RPC that terminated with:
status = StatusCode.UNAVAILABLE
details = “failed to connect to all addresses”
debug_error_string = “{“created”:”@1695324105.208465198",“description”:“Failed to pick subchannel”,“file”:“src/core/ext/filters/client_channel/client_channel.cc”,“file_line”:3260,“referenced_errors”:[{“created”:“@1695324105.208464852”,“description”:“failed to connect to all addresses”,“file”:“src/core/lib/transport/error_utils.cc”,“file_line”:167,“grpc_status”:14}]}"
2023-09-21 19:21:46 [2,553ms] [Error] [omni.exp.graph.composer.node_registry_model] Registry Model update failed
