• RTX A6000(GPU)
• DeepStream Version 6.3
• TensorRT Version 8.5
• NVIDIA GPU Driver Version 525.125.06(valid for GPU only)
• Issue Type( questions )
I am trying to work with the graph composer on the new DS 6.3. When I startup the composer, I receive the following errors:
2023-08-21 01:25:27 [Error] [omni.exp.graph.composer.registry_window] Failed to get repo list: <AioRpcError of RPC that terminated with:
2023-08-21 01:25:27 [Error] [omni.exp.graph.composer.registry_window] status = StatusCode.UNAVAILABLE
2023-08-21 01:25:27 [Error] [omni.exp.graph.composer.registry_window] details = "failed to connect to all addresses"
2023-08-21 01:25:27 [Error] [omni.exp.graph.composer.registry_window] debug_error_string = "{"created":"@1692581127.726655544","description":"Failed to pick subchannel","file":"src/core/ext/filters/client_channel/client_channel.cc","file_line":3260,"referenced_errors":[{"created":"@1692581127.726654421","description":"failed to connect to all addresses","file":"src/core/lib/transport/error_utils.cc","file_line":167,"grpc_status":14}]}"
2023-08-21 01:25:27 [Error] [omni.exp.graph.composer.registry_window] >
2023-08-21 01:25:28 [Error] [omni.exp.graph.composer.node_registry_model] Registry Model update failed
How to solve this problem?
