• Hardware Platform (Jetson / GPU) 4090
• DeepStream Version 7.0
• TensorRT Version
When referring to the sample from the DeepStream parallel pipeline at
https://github.com/NVIDIA-AI-IOT/deepstream_reference_apps/tree/master/deepstream_parallel_inference_app,
I have a question: why is it necessary to use streamdemux? Is it mandatory?
In the diagram below, the upper example follows the structure shown in the sample.
However, in the second diagram, I propose using uridecodebin directly connected to a tee, and then from the tee branching out to multiple streammux elements — one for each pipeline branch.
Would this approach work?
If not, could you please explain why it’s not recommended and why the streamdemux element is required in this case?
Thank you.
