Hi all, @kesong @junshengy
I’m having an issue using DeepStream to consume an RTSP stream coming from VST. The stream URL is like this:
rtsp://10.63.142.104:8555/live/D11
When I use this RTSP URL in DeepStream, I consistently get the following error:
WARNING from src: Could not open resource for reading.
Debug info: ../gst/rtsp/gstrtspsrc.c(6427): gst_rtspsrc_setup_auth (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin3/GstRTSPSrc:src:
No supported authentication protocol was found
WARNING from src: Not found
Stream Not Found (404)
Active sources : 0
Tue Sep 9 06:45:46 2025
**PERF:
0.00 (0.00) source_id : 3 stream_name D39
0.00 (0.00) source_id : 2 stream_name D35
0.00 (0.00) source_id : 4 stream_name D11
0.00 (0.00) source_id : 1 stream_name D50
0.00 (0.00) source_id : 0 stream_name D46
However, when I open the same URL in ffplay, it works fine and I can see the video stream:
ffplay rtsp://10.63.142.104:8555/live/D11
Also, I can view the stream perfectly through the VST Web UI, which indicates the stream is active and accessible.
Some additional observations:
This issue only occurs when the RTSP stream is directly from the camera added to VST.
If I use an RTSP stream from a video file in memory (also via VST), DeepStream works without errors.
So it seems DeepStream fails only when the RTSP is a live passthrough from a physical camera via VST.
Here is part of the DeepStream log output when the error occurs:
transformer models will be used.
Copying onnx-files to DS docker volume for perserving PVCs…
(gst-plugin-scanner:29): GStreamer-WARNING **: 06:45:30.084: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstopenmpt.so’: libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:29): GStreamer-WARNING **: 06:45:30.122: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2dec.so’: libmpeg2.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:29): GStreamer-WARNING **: 06:45:30.130: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpg123.so’: libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:29): GStreamer-WARNING **: 06:45:30.195: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2enc.so’: libmpeg2encpp-2.1.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:29): GStreamer-WARNING **: 06:45:30.370: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstchromaprint.so’: libavcodec.so.58: cannot open shared object file: No such file or directory
(gst-plugin-scanner:35): GStreamer-WARNING **: 06:45:30.554: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:35): GStreamer-WARNING **: 06:45:30.657: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:35): GStreamer-WARNING **: 06:45:30.668: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ucx.so’: libucs.so.0: cannot open shared object file: No such file or directoryStarting Deepstream FSL AppTiled text: 0Playback UTC: 0PGIE model used: 1no-force-tcp: 1Log level: 5Message rate: 1target-class: 1
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8555/ds-test ***
Civetweb version: v1.16Server running at port: 9000gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so[NvMultiObjectTracker] Loading TRT Engine for tracker ReID…[NvMultiObjectTracker] Loading Complete!ERROR: [TRT]: 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.)[NvMultiObjectTracker] Initialized0:00:11.066941687 28 0x621689e17350 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/opt/storage/dino_model_op17.onnx_b4_gpu0_fp16.engine0:00:11.429427648 28 0x621689e17350 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /opt/storage/dino_model_op17.onnx_b4_gpu0_fp16.engine0:00:11.438007554 28 0x621689e17350 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.4/sources/apps/sample_apps/deepstream-fewshot-learning-app/ds-mtmc-pgie-config.yml sucessfullyINFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [FullDims Engine Info]: layers num: 30 INPUT kFLOAT inputs 3x544x960 min: 1x3x544x960 opt: 4x3x544x960 Max: 4x3x544x9601 OUTPUT kFLOAT pred_logits 900x4 min: 0 opt: 0 Max: 02 OUTPUT kFLOAT pred_boxes 900x4 min: 0 opt: 0 Max: 0
Runtime commands:h: Print this helpq: Quit
p: Pause r: Resume
Active sources : 0
**PERF:Tue Sep 9 06:45:41 2025**PERF:
new stream added [0:D46:D46]
new stream added [1:D50:D50]
new stream added [2:D35:D35]
new stream added [3:D39:D39]
new stream added [4:D11:D11]
** INFO: <bus_callback:301>: Pipeline ready
** INFO: <bus_callback:287>: Pipeline running
WARNING from src: Could not open resource for reading.Debug info: ../gst/rtsp/gstrtspsrc.c(6427): gst_rtspsrc_setup_auth (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin3/GstRTSPSrc:src:No supported authentication protocol was foundWARNING from src: Not foundDebug info: ../gst/rtsp/gstrtspsrc.c(6736): gst_rtspsrc_send (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin3/GstRTSPSrc:src:Stream Not Found (404)WARNING from src: Could not open resource for reading.Debug info: ../gst/rtsp/gstrtspsrc.c(6427): gst_rtspsrc_setup_auth (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin0/GstRTSPSrc:src:No supported authentication protocol was foundWARNING from src: Not foundDebug info: ../gst/rtsp/gstrtspsrc.c(6736): gst_rtspsrc_send (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin0/GstRTSPSrc:src:Stream Not Found (404)WARNING from src: Could not open resource for reading.Debug info: ../gst/rtsp/gstrtspsrc.c(6427): gst_rtspsrc_setup_auth (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin4/GstRTSPSrc:src:No supported authentication protocol was foundWARNING from src: Not foundDebug info: ../gst/rtsp/gstrtspsrc.c(6736): gst_rtspsrc_send (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin4/GstRTSPSrc:src:Stream Not Found (404)WARNING from src: Could not open resource for reading.Debug info: ../gst/rtsp/gstrtspsrc.c(6427): gst_rtspsrc_setup_auth (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin1/GstRTSPSrc:src:No supported authentication protocol was foundWARNING from src: Not foundDebug info: ../gst/rtsp/gstrtspsrc.c(6736): gst_rtspsrc_send (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin1/GstRTSPSrc:src:Stream Not Found (404)WARNING from src: Could not open resource for reading.Debug info: ../gst/rtsp/gstrtspsrc.c(6427): gst_rtspsrc_setup_auth (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin2/GstRTSPSrc:src:No supported authentication protocol was foundWARNING from src: Not foundDebug info: ../gst/rtsp/gstrtspsrc.c(6736): gst_rtspsrc_send (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin2/GstRTSPSrc:src:Stream Not Found (404)Active sources : 0Tue Sep 9 06:45:46 2025**PERF:0.00 (0.00) source_id : 3 stream_name D390.00 (0.00) source_id : 2 stream_name D350.00 (0.00) source_id : 4 stream_name D110.00 (0.00) source_id : 1 stream_name D500.00 (0.00) source_id : 0 stream_name D46
Active sources : 0Tue Sep 9 06:45:51 2025**PERF:0.00 (0.00) source_id : 3 stream_name D390.00 (0.00) source_id : 2 stream_name D350.00 (0.00) source_id : 4 stream_name D110.00 (0.00) source_id : 1 stream_name D500.00 (0.00) source_id : 0 stream_name D46
Active sources : 0Tue Sep 9 06:45:56 2025**PERF:0.00 (0.00) source_id : 3 stream_name D390.00 (0.00) source_id : 2 stream_name D350.00 (0.00) source_id : 4 stream_name D110.00 (0.00) source_id : 1 stream_name D500.00 (0.00) source_id : 0 stream_name D46
Active sources : 0Tue Sep 9 06:46:01 2025**PERF:0.00 (0.00) source_id : 3 stream_name D390.00 (0.00) source_id : 2 stream_name D350.00 (0.00) source_id : 4 stream_name D110.00 (0.00) source_id : 1 stream_name D500.00 (0.00) source_id : 0 stream_name D46
Resetting source rtsp://10.63.142.104:8555/live/D11WARNING from dsnvurisrcbin4: No data from source rtsp://10.63.142.104:8555/live/D11 since last 30 sec. Trying reconnectionDebug info: gstdsnvurisrcbin.cpp(1286): watch_source_status (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin4WARNING from src: Could not open resource for reading.Debug info: ../gst/rtsp/gstrtspsrc.c(6427): gst_rtspsrc_setup_auth (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin4/GstRTSPSrc:src:No supported authentication protocol was foundWARNING from src: Not foundDebug info: ../gst/rtsp/gstrtspsrc.c(6736): gst_rtspsrc_send (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin4/GstRTSPSrc:src:Stream Not Found (404)Resetting source rtsp://10.63.142.104:8555/live/D39WARNING from dsnvurisrcbin3: No data from source rtsp://10.63.142.104:8555/live/D39 since last 33 sec. Trying reconnectionDebug info: gstdsnvurisrcbin.cpp(1286): watch_source_status (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin3WARNING from src: Could not open resource for reading.Debug info: ../gst/rtsp/gstrtspsrc.c(6427): gst_rtspsrc_setup_auth (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin3/GstRTSPSrc:src:No supported authentication protocol was foundWARNING from src: Not foundDebug info: ../gst/rtsp/gstrtspsrc.c(6736): gst_rtspsrc_send (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin3/GstRTSPSrc:src:Stream Not Found (404)Active sources : 0Tue Sep 9 06:46:06 2025**PERF:0.00 (0.00) source_id : 3 stream_name D390.00 (0.00) source_id : 2 stream_name D350.00 (0.00) source_id : 4 stream_name D110.00 (0.00) source_id : 1 stream_name D500.00 (0.00) source_id : 0 stream_name D46
Resetting source rtsp://10.63.142.104:8555/live/D35WARNING from dsnvurisrcbin2: No data from source rtsp://10.63.142.104:8555/live/D35 since last 36 sec. Trying reconnectionDebug info: gstdsnvurisrcbin.cpp(1286): watch_source_status (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin2mimetype is video/x-rawResetting source rtsp://10.63.142:8555/live/D50WARNING from dsnvurisrcbin1: No data from source rtsp://10.63.142.104:8555/live/D50 since last 39 sec. Trying reconnectionDebug info: gstdsnvurisrcbin.cpp(1286): watch_source_status (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin1Active sources : 0Tue Sep 9 06:46:11 2025**PERF:0.00 (0.00) source_id : 3 stream_name D390.00 (0.00) source_id : 2 stream_name D350.00 (0.00) source_id : 4 stream_name D110.00 (0.00) source_id : 1 stream_name D500.00 (0.00) source_id : 0 stream_name D46
WARNING from dsnvurisrcbin0: No data from source rtsp://10.62.162.104:8555/live/D46 since last 42 sec. Trying reconnectionDebug info: gstdsnvurisrcbin.cpp(1286): watch_source_status (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin0Resetting source rtsp://10.63.142.104:8555/live/D46Active sources : 0Tue Sep 9 06:46:16 2025**PERF:0.00 (0.00) source_id : 3 stream_name D390.00 (0.00) source_id : 2 stream_name D350.00 (0.00) source_id : 4 stream_name D110.00 (0.00) source_id : 1 stream_name D500.00 (0.00) source_id : 0 stream_name D46
Active sources : 0Tue Sep 9 06:46:21 2025**PERF:0.00 (0.00) source_id : 3 stream_name D390.00 (0.00) source_id : 2 stream_name D350.00 (0.00) source_id : 4 stream_name D110.00 (0.00) source_id : 1 stream_name D500.00 (0.00) source_id : 0 stream_name D46
Active sources : 0Tue Sep 9 06:46:26 2025**PERF:0.00 (0.00) source_id : 3 stream_name D390.00 (0.00) source_id : 2 stream_name D350.00 (0.00) source_id : 4 stream_name D110.00 (0.00) source_id : 1 stream_name D500.00 (0.00) source_id : 0 stream_name D46
Active sources : 0Tue Sep 9 06:46:31 2025**PERF:0.00 (0.00) source_id : 3 stream_name D390.00 (0.00) source_id : 2 stream_name D350.00 (0.00) source_id : 4 stream_name D110.00 (0.00) source_id : 1 stream_name D500.00 (0.00) source_id : 0 stream_name D46
Resetting source rtsp://10.63.142.104:8555/live/D11WARNING from dsnvurisrcbin4: No data from source rtsp://10.63.142.104:8555/live/D11 since last 30 sec. Trying reconnectionDebug info: gstdsnvurisrcbin.cpp(1286): watch_source_status (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin4WARNING from dsnvurisrcbin3: No data from source rtsp://10.63.142.104:8555/live/D39 since last 30 sec. Trying reconnectionDebug info: gstdsnvurisrcbin.cpp(1286): watch_source_status (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin3Resetting source rtsp://10.63.142.104:8555/live/D39Active sources : 0Tue Sep 9 06:46:36 2025**PERF:0.00 (0.00) source_id : 3 stream_name D390.00 (0.00) source_id : 2 stream_name D350.00 (0.00) source_id : 4 stream_name D110.00 (0.00) source_id : 1 stream_name D500.00 (0.00) source_id : 0 stream_name D46
Has anyone encountered a similar problem? Is there any known limitation with DeepStream and certain types of RTSP sources (like live camera passthrough via VST)? Any suggestions or debugging steps would be greatly appreciated.
