Please provide complete information as applicable to your setup. • Hardware Platform (Jetson / GPU) Jetson AGX • DeepStream Version 7.0
**• JetPack Version (valid for Jetson only) 6.0 GA
**• TensorRT Version 8.6
**• NVIDIA GPU Driver Version (valid for GPU only) 540.3.0
**• Issue Type( questions, new requirements, bugs) questions • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
Deepstream-test5-app run for a while the Active sources drop to zero with Multiple sources
1、open deepstream-test5-app, and use restful api to add the stream.
2、see the log , for a while, you can see this situation
I do not know how to produce this situation
