• Hardware Platform (Jetson / GPU): GPU
• DeepStream Version:6.4
| NVIDIA-SMI 525.147.05 Driver Version: 525.147.05 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:01:00.0 Off | N/A |
| N/A 41C P0 N/A / 80W | 6MiB / 6144MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2843 G /usr/lib/xorg/Xorg 4MiB |
I am using 6.4-gc-triton-devel, for running deepstream-test5 application, I facing the following error by enabling the Kafka sink.
[sink1]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvoverlaysink 6=MsgConvBroker
type=6
msg-conv-config=dstest5_msgconv_sample_config.txt
#(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
#(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
#(256): PAYLOAD_RESERVED - Reserved type
#(257): PAYLOAD_CUSTOM - Custom schema payload
msg-conv-payload-type=1
msg-conv-msg2p-new-api= 1
msg-conv-frame-interval= 1
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream-6.4/lib/libnvds_kafka_proto.so
#Provide your msg-broker-conn-str here
msg-broker-conn-str=192.168.29.17;9092
#msg-broker-conn-str=192.168.2.7;9092
topic=quickstart-events
#Optional:
#msg-broker-config=…/…/deepstream-test4/cfg_kafka.txt
I am facing the below error:
./deepstream-test5-app -c configs/test5_config_file_src_infer.txt
(gst-plugin-scanner:2860): GStreamer-WARNING **: 04:58:53.124: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_deepstream_bins.so’: ///opt/nvidia/deepstream/deepstream-6.4/lib/libnvds_msgconv.so: undefined symbol: _ZN7ds3dmsg15LidarPointCloudD1Ev
(gst-plugin-scanner:2860): GStreamer-WARNING **: 04:58:53.127: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_msgconv.so’: ///opt/nvidia/deepstream/deepstream-6.4/lib/libnvds_msgconv.so: undefined symbol: _ZN7ds3dmsg15LidarPointCloudD1Ev
(gst-plugin-scanner:2860): GStreamer-WARNING **: 04:58:53.130: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2860): GStreamer-WARNING **: 04:58:53.170: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstopenmpt.so’: libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2860): GStreamer-WARNING **: 04:58:53.194: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpg123.so’: libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2860): GStreamer-WARNING **: 04:58:53.209: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2dec.so’: libmpeg2.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2860): GStreamer-WARNING **: 04:58:53.220: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstchromaprint.so’: libavcodec.so.58: cannot open shared object file: No such file or directory
GLib (gthread-posix.c): Unexpected error from C library during ‘pthread_setspecific’: Invalid argument. Aborting.
(gst-plugin-scanner:2868): GStreamer-WARNING **: 04:58:53.613: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2enc.so’: libmpeg2encpp-2.1.so.0: cannot open shared object file: No such file or directory
** ERROR: <create_msg_conv_broker_bin:251>: Failed to create ‘sink_sub_bin_transform1’
** ERROR: <create_msg_conv_broker_bin:291>: create_msg_conv_broker_bin failed
** ERROR: <create_sink_bin:862>: create_sink_bin failed
** ERROR: <create_processing_instance:1230>: create_processing_instance failed
** ERROR: <create_pipeline:1863>: create_pipeline failed
** ERROR: main:1511: Failed to create pipeline
Quitting
nvstreammux: Successfully handled EOS for source_id=0
nvstreammux: Successfully handled EOS for source_id=1
nvstreammux: Successfully handled EOS for source_id=2
nvstreammux: Successfully handled EOS for source_id=3
App run failed
Kindly need your help on this issue
