Both my deepstream-test4 and deepstream-test5 can use Kafka normally, but when I run deepstream-app, my Kafka always cannot receive data. How can I solve this problem, thank you for your answer!!!
• DeepStream Version
• TensorRT Version
test5 app builds on top of deepstream-app, you can use it for message conversion and transfering. if you still need deepstream-app for this, please share your configuration and any changes made to repro your issue.
My system:
Ubuntu 20.04
Tesla T4
Driver: 470.47
CUDA 11.1
cuDNN 8.1
TensorRT 7.2
DeepStream SDK 5.1.0
Hello I need to use deepstream-app, I try to run deepstream-app source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt to realize data transmission by kafka, but it doesn’t work.
My source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt is modified as follows:
[sink1]
enable=1
type=6
msg-conv-config =dstest5_msgconv_config.txt
msg-conv-payload-type=0
msg-broker-proto-lib=/mnt/sdc/deepstream/deepstream-5.1/lib/libnvds_kafka_proto.so
msg-broker-conn-str=10.228.1.230;9092;test
topic=test
It is worth mentioning that:
Kafka can be used normally when I run deepstream-test4 and deepstream-test5. Looking forward to your answers, thank you very much
hi,
did you solve this issue? I am facing the same problem.
I use deepstream-test5 to build my program
