Are you crash every time when setting timezone?
Are you flash r32.3.1 using flash command or sdkmanager or Etcher tool?
The username and password is from system configuration setup proceed, that username and password setup by yourself.
I used r32.3.1 and etcher. The default login and password that appear to have been created on the sd card persisted across restarts and also after reflashing the sd card.
I fixed this by a full reformat and reflash of the image. Then completed setup using monitor and mouse.
