Hi guys,
I’m currently working with Jetson Nano, I want to set my Nano logged in automatically and unfortunately, I chose password mode to “None”. After I changed it, when I reboot my system, it still require password to login but when I type my old password, it turn me invalid passwd. Now I can do nothing to login my nano again. So can you guys help me with this issue? Or I have to re-flash my microSD card and get a new environment? That was really sad!
Any help are much appreciated! Many thanks!
Rabbit.
Could you give us the steps (configuration) how you got this error?
Hi sir,
Firstly at User Accounts, I turn Automatic login ON then I restart my Nano, it worked, it logged in automatically but when my screen off, it required passwd again so I think I will set my Nano with “None” passwd mode ON. I chose “change” and “lock” this action, when I reboot my Nano, issue came up as I described before. Did you get my issue, sir? Thanks!
Thanks. We will check this issue.
Thank you sir, this time I really need to access again to my Nano. Could you give me the way to solve this issue? I cannot open Terminal so I think I have to write new image for my microSD card : (
Currently you could use the console and see if you could login the console.
Method 1. Run ctrl+alt + f1~6 and see if the console shows up on your screen.
Method 2. Enable serial console.
If you can login, then please try to add new user/password to the system and see if you can login desktop again.
OMG! It worked, sir!
“Ctrl+Alt+F5” brought me back to the console windows and I change my password to login back again.
Thank you very much for your help, I almost desperate, you saved me sir.
Many thanks with respect!
