I have a problem when trying to define “A62 - SOC_GPIO50 - GPIO3_PBB.02” as an input.
That is defined in the devkit as “CAM_FRSYNC1 (CIM PIN#85)”.
Jetson Orin AGX 64GB, JetPeck 36.4.4
soc_gpio50_pbb2 {
nvidia,pins = “soc_gpio50_pbb2”;
nvidia,function = “gp”;
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,tristate = <TEGRA_PIN_ENABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
nvidia,io-high-voltage = <TEGRA_PIN_ENABLE>;
nvidia,lpdr = <TEGRA_PIN_DISABLE>;
I do not see any changes when monitoring the IO.
The cmd “gpioget -c 1 10” always returns 1, even when connecting a scope to the line, I see 0 (study 0)
gpiomon -c 1 10
I thought maybe my design is worng so I changed the pin at the pinmux to be output, and I see instead of 3.3V a ~2V, which is good as the two resistors are “fighting” between them. Meaning I’m on the right PIN.
I know that it belongs to the camera (all camera dtsi are using it), but I did not load or include any camera dtsi files.
This is the pinmux filename:
tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi
The same thing occurs on the devkit, but I did not know the whole line where it goes, and if something else drives it at the devkit.
Event add it to the gpio.dtis to be defined as input:
filename: tegra234-mb1-bct-gpio-p3701-0000.dtsi
gpio@c2f0000 {
gpio-init-names = "default";
gpio-init-0 = <&gpio_aon_default>;
gpio_aon_default: default {
gpio-input = <
TEGRA234_AON_GPIO(BB, 2)
gpio-output-low = <
gpio-output-high = <
What am I missing? :(
Update:
Used the spreadsheet from NVIDIA Jetson and generated the same PIN to be GPIO and INPUT PULL NONE, got the same gpio.dtsi and pinmux as i wrote.
does not help.
