On my custom orin-nx/JP6 based system I am adding the below snipped to the device tree. Compiles fine, and it shows up in the correct node under /sys/firmware/devicetree.base. Double checked, the device is at pcie@14100000.
However the PCIe device is not picking up the device tree change at all, and also the phy connection is not being made.
Is there anything I am missing ? This used to work fine for Jetson-Nano with kernel series 4,x
-----------------------------------------lan743x.dtsi -------------------------------------------
bus@0 {
pcie@14100000 {
compatible = "nvidia,tegra234-pcie";
#address-cells = <3>;
#size-cells = <2>;
bus-range = <0x00 0xff>;
pci@1,0 {
ethernet@0,0 {
compatible = "pci1055,7431";
reg = <0x00010000 0 0 0 0>;
nvidia,num-lanes = <1>;
label = "lan743x";
local-mac-address = [00 11 22 33 44 55];
phy-connection-type = "rgmii";
phy-handle = <&switch_cpu_port>;
mdio {
#address-cells = <1>;
#size-cells = <0>;
switch0: ethernet-switch@0 {
compatible = "microchip,ksz9477";
reg = <0>;
microchip,synclko-125;
ports {
#size-cells = <0>;
switch_cpu_port:port@0 {
reg = <0>;
label = "cpu-port";
phy-mode = "rgmii";
port@1 {
reg = <1>;
label = "switch-port1";
phy-mode = "rgmii";
port@2 {
reg = <2>;
label = "switch-port2";
phy-mode = "rgmii";
