Demo is live but not working properly (cannot upload videos or use sample)
I am running the agents on 8 H100 SXM5. I managed to setup the application, but when trying to upload a video on the UI, I get an error
Unsupported file type - file:///tmp/gradio/2ad870c6bd8fcf516e4ab668ac83c262fc1e01574b91bb05346126c136722a0f/video.mp4 Error:gst-core-error-quark: Your GStreamer installation is missing a plug-in. (12)
I run this command before launching, but I still get this popup error.
sudo apt install gstreamer1.0-tools gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly gstreamer1.0-libav -y
Also, the select a sample list is empty and shows no videos.
Could you attach your video source file? The application is deployed based on docker, so your local Gstreamer command is invalid.
Makes sense. I tried with at least 10 different videos, mostly mp4. Here is one of them
There’s nothing unusual about this video. Have you installed the corresponding version of the software by referring to our Guide Prerequisites on your host?
Yes. I deployed on Lambda using Lambda stack, which has built in latest Nvidia drivers, ubuntu 22.04 and Cuda. The application runs without any errors and only appears problematic when I try to upload a file. It also does not show the sample videos. I also tried a request on the api endpoint directly, but it threw same error.
We recommend that you install the driver and cuda version like below. Could you try that on your side?
NVIDIA driver 535.161.08
CUDA 12.2
