Detectnet: failed to capture video frame
Running detectnet on AGX Xavier and can’t read video file.
The command is
./detectnet --input_URI=file:///opt/nvidia/deepstream/deepstream-5.0/samples/streams/IMG_5715.MOV --model=/home/xavier/Desktop/jetson-inference/platerecg/models/numplate_resnet_18_fp32.etlt_b1_gpu0_fp16.engine --labels=/home/xavier/Desktop/jetson-inference/platerecg/labels/labels.txt --input-blob=input_1 --output-bbox=output_bbox/BiasAdd --output-cvg=output_cov/Sigmoid --batch-size=1 --threshold=0.5 --overlay='box' --input-width=1920 --input-height=1080 --input-flip=none
Log infos are
xavier@xavier-desktop:~/Desktop/jetson-inference/build/aarch64/bin$ ./detectnet --input_URI=file:///opt/nvidia/deepstream/deepstream-5.0/samples/streams/central3.mp4 --model=/home/xavier/Desktop/jetson-inference/platerecg/models/numplate_resnet_18_fp32.etlt_b1_gpu0_fp16.engine --labels=/home/xavier/Desktop/jetson-inference/platerecg/labels/labels.txt --input-blob=input_1 --output-bbox=output_bbox/BiasAdd --output-cvg=output_cov/Sigmoid --batch-size=1 --threshold=0.5 --overlay='box' --input-width=1920 --input-height=1080 --input-codec=mpeg4
[gstreamer] initialized gstreamer, version 1.14.5.0
[gstreamer] gstCamera -- attempting to create device csi://0
[gstreamer] gstCamera pipeline string:
[gstreamer] nvarguscamerasrc sensor-id=0 ! video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=30/1, format=(string)NV12 ! nvvidconv flip-method=2 ! video/x-raw ! appsink name=mysink
[gstreamer] gstCamera successfully created device csi://0
[video]  created gstCamera from csi://0
gstCamera video options:
  -- URI: csi://0
     - protocol:  csi
  -- deviceType: csi
  -- ioType:     input
  -- codec:      raw
  -- width:      1920
  -- height:     1080
  -- frameRate:  30.000000
  -- bitRate:    0
  -- numBuffers: 4
  -- zeroCopy:   true
  -- flipMethod: rotate-180
  -- loop:       0
[OpenGL] glDisplay -- X screen 0 resolution:  1920x1080
[OpenGL] glDisplay -- X window resolution:    1920x1080
[OpenGL] glDisplay -- display device initialized (1920x1080)
Even though --input_URI=file:///opt/nvidia/deepstream/deepstream-5.0/samples/streams/IMG_5715.MOV is set, loginfo shows that – URI: csi://0 and it is reading from device.
Need to input as
./detectnet file:///home/xavier/Desktop/jetson-inference/platerecg/IMG_5715.mp4
YES.
You can find the detail usage here:
