Detectnet_v2(resnet50) low accuracy on 2 class dataset
I am afraid yes. Please check
  1. Are the labels correct? Especially for the “healthy” class.
  2. More, how many images for these two classes separately?
  3. Set to the same
    initial_weight: 10.0
    weight_target: 10.0
  4. Can you share latest training spec?
“healthy” image and label files have a “0” as the first digit:
They start at “000001” and are not entirely consecutive e.g:
000016.txt (76 Bytes)
“damage” image and label files have a “1” as the first digit:
100268.txt (74 Bytes)
I believe the labels are 100% correct. I hand-labelled them and I have checked them very carefully.
Blockquote
In train/val: 531 “healthy”, 531 “damage”
In test: 10 “healthy”, 10 “damage”
Blockquote
currently the settings in “cost_function_config” are:
cost_function_config {
target_classes {
class_weight: 8.0
coverage_foreground_weight: 0.0500000007451
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 1.0
target_classes {
class_weight: 1.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
To be 100% sure: do you want me to reset the initial_weight and weight_target of both classes to 10.0?
Blockquote
detectnet_v2_train_resnet50_kitti.txt (4.2 KB)
This is the latest training spec before I reset the initial_weight and weight_target of both classes to 10.0.
For healthy class, from the label file,
healthy 0.00 0 0.00 0.0 0.0 3648.0 1417.0 0.00 0.00 0.00 0.00 0.00 0.00 0.00
It is 1920x746 image, why the bbox is (0.0 0.0 3648.0 1417.0) ?
image size of 000016.jpg is 3648 x 1417. I guess the forum formatting has resized the image that you are seeing. The label is correct.
Problem solved. I had the coverage_threshold for “healthy” in postprocessing_config set too high. Interestingly, when I lowered it the first time the average precision of “damage” improved and “healthy” stayed at “0”. It encouraged me to lower it further and, finally, I got a non-zero value for “healthy” too.
These experiments are only run for 10 epochs, so I am hopeful that further improvements are possible at ~ 120 epochs.
Basically I had not fully appreciated what “mean average precision” was doing and what it was affected by.
I found this blog helpful:
https://machinethink.net/blog/object-detection
Thank you for being a great help.
