I trained model on detect-net v2 with classifiers(Resnet10 and Resnet18). The Mean average Precision on Resnet10 is 37, while on Resnet18 it’s 44.05.
I have one class for training (person) and below datasets details are mentioned,
Training Images : 103,851
Testing Images : 24,414
According to detectnetv2 official documentation, I resize all dateset images to same size (640,480), also resize bounding boxes, but the results are not as I expected.
why this happened, because sometimes deep learning models need more data for best performance. but here situation opposite.
Here My Kitti-train-val file
kitti_config {
root_directory_path: "/workspace/tlt-experiments/data/training"
image_dir_name: "image_2"
label_dir_name: "label_2"
image_extension: ".jpg"
partition_mode: "random"
num_partitions: 2
val_split: 20
num_shards: 20
image_directory_path: "/workspace/tlt-experiments/data/training"
Below is my training spec file attached for Resnet10
random_seed: 42
dataset_config {
data_sources {
tfrecords_path: "/workspace/tlt-experiments/data/tfrecords/kitti_trainval/*"
image_extension: "jpg"
target_class_mapping {
key: "person"
value: "person"
validation_fold: 0
augmentation_config {
preprocessing {
output_image_width: 640
output_image_height: 480
min_bbox_width: 1.0
min_bbox_height: 1.0
output_image_channel: 3
spatial_augmentation {
hflip_probability: 0.5
vflip_probability: 0.0
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
color_shift_stddev: 0.0
hue_rotation_max: 25.0
saturation_shift_max: 0.2
contrast_scale_max: 0.1
contrast_center: 0.5
postprocessing_config {
target_class_config {
key: "person"
value {
clustering_config {
clustering_algorithm: DBSCAN
dbscan_confidence_threshold: 0.9
coverage_threshold: 0.005
dbscan_eps: 0.15
dbscan_min_samples: 0.05
minimum_bounding_box_height: 20
model_config {
pretrained_model_file: "/workspace/tlt-experiments/detectnet_v2/pretrained_resnet10/tlt_pretrained_detectnet_v2_vresnet10/resnet10.hdf5"
num_layers: 10
freeze_blocks: 0
freeze_blocks: 1
all_projections: True
use_pooling: False
use_batch_norm: True
dropout_rate: 0.0
use_batch_norm: true
objective_set {
bbox {
scale: 35.0
offset: 0.5
cov {
training_precision {
backend_floatx: FLOAT32
arch: "resnet"
evaluation_config {
validation_period_during_training: 5
first_validation_epoch: 1
minimum_detection_ground_truth_overlap {
key: "person"
value: 0.5
evaluation_box_config {
key: "person"
value {
minimum_height: 4
maximum_height: 9999
minimum_width: 4
maximum_width: 9999
average_precision_mode: INTEGRATE
cost_function_config {
target_classes {
class_weight: 1.0
coverage_foreground_weight: 0.05
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
enable_autoweighting: true
max_objective_weight: 0.999899983406
min_objective_weight: 9.99999974738e-05
training_config {
batch_size_per_gpu: 16
num_epochs: 120
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-06
max_learning_rate: 5e-04
soft_start: 0.1
annealing: 0.7
regularizer {
type: L1
weight: 3e-9
optimizer {
adam {
epsilon: 9.99999993923e-09
beta1: 0.9
beta2: 0.999
cost_scaling {
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
checkpoint_interval: 5
bbox_rasterizer_config {
key: "person"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.4
cov_radius_y: 0.4
bbox_min_radius: 1.0
deadzone_radius:0.67
Below is my training spec file attached for Resnet18
random_seed: 42
dataset_config {
data_sources {
key: "person"
value: "person"
validation_fold: 0
preprocessing {
min_bbox_width: 1.0
zoom_min: 1.0
zoom_max: 1.0
key: "person"
value {
clustering_config {
dbscan_eps: 0.15
model_config {
pretrained_model_file: "/workspace/tlt-experiments/detectnet_v2/pretrained_resnet18/tlt_pretrained_detectnet_v2_vresnet18/resnet18.hdf5"
num_layers: 18
freeze_blocks: 0
freeze_blocks: 1
use_pooling: False
dropout_rate: 0.0
objective_set {
bbox {
scale: 35.0
offset: 0.5
cov {
arch: "resnet"
evaluation_config {
key: "person"
value: 0.5
key: "person"
value {
minimum_height: 4
minimum_width: 4
maximum_width: 9999
target_classes {
class_weight: 1.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
training_config {
num_epochs: 120
learning_rate {
soft_start: 0.1
annealing: 0.7
regularizer {
type: L1
weight: 3e-9
optimizer {
adam {
beta1: 0.9
beta2: 0.999
cost_scaling {
increment: 0.005
decrement: 1.0
key: "person"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.4
cov_radius_y: 0.4
Below Results are on Resnet18.
