I believe this may be a bug in jetpack 2.2.1. Reproduce case:
- login as ubuntu user
- create a new user as follows: ``` sudo adduser anewuser sudo usermod -a -G sudo anewuser ```
- ssh in as the new user. Try to run the deviceQuery executable from the CUDA Samples. Receive error
/home/ubuntu/NVIDIA_CUDA-7.0_Samples/bin/aarch64/linux/release/deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 30
→ unknown error
Result = FAIL</li> <li>Typesudo chmod 0666 /dev/nv*
to fix the permissions on the /dev/nv files. </li> <li>Retry deviceQuery. It should work now.</li> <li>press the reset button on the device.</li> <li>login as the new user</li> <li>Try to run deviceQuery again and observe a failure. Retype the chmod command to get it working again.</li> </ul> Hopefully this can get into the next release of JP.
