/dev/sdb1 : clean, 640729/122388848… and Keyboard is not working
/dev/sdb1 : clean, 640729/122388848 files… blocks And keyboard is not active, keyboard doesn’t work
Ubuntu 16.04
NVIDIA GPU 1080ti
I cannot open the computer. /dev/sdb1 : clean message stays there. Cntrl+Alt+f1 or Cntrl+Alt+f7 is not working because keyboard is not working.
It is a dual boot. I installed windows 10. I installed ubuntu to ssd. Before start, there are options : Ubuntu Windows etc. Then keyboard is working in this screen. But when I choose ubuntu, and enter, Then : /dev/sdb1 message stays on screen and keyboard is not working. And not start.
So how can I fix ?
Did you already install the nvidia driver?
Yes, it was working first.
But after for a while, it started not to run. Hanging “/dev/sdb1 : clean” on black screen.
I tried to fix via grub with root prompt:
$ sudo apt update then receiving error : Could not resolve ‘developer.download.nvidia.com’ Could not resolve ‘tr.archive.ubuntu.com
$ sudo apt upgrade Could not resolve ‘tr.archive.ubuntu.com
(I use dual boot : Windows and Ubuntu.)
It was running, but it started not to run after 04.10.2018 gpu Windows driver updates. I cannot open ubuntu boot. Black screen frozen with “/dev/sdb1 : clean”.
Is it temporary issue because of gpu driver updates or should I fix something ?
If you can get to the prompt, try uninstalling the nvidia driver
sudo apt-get purge nvidia*
so your system falls back to intel/nouveau. Then see if you can reinstall the driver from ppa:
Yes, I removed nvidia driver.
And installed again.
It is running now. Solved.
But I need to disables automatic NVIDIA driver updates/cuda updates/ubuntu updates/Windows updates,etc.
How can I do it ?
I use Ubuntu 16.04 and Windows as dual boot. Same NVIDIA GPU.
So I think I need to disable all to make stable system.
Windows updates should not have any effect on the drivers in the Ubuntu partition. That was most likely just a coincidence.
If this happens again, just report it as a bug to the ubuntu bugzilla, always keep an eye on what gets updated.
In my case it was due to gdm3 not running. So I restarted it using these commands:
sudo service gdm3 status (to ckeck status)
sudo service gdm3 start
It doesn’t matter if you are using lightgdm, gdm or gdm. To find out which one you are using try sudo service --status-all | grep gdm
I have the same problem upon turning on Ubuntu 18.04 with Nvidia 2070 Super. While I turn off the Ubuntu 18.04 and turn on it again. It goes back to the normal state. It is just like a bug for the Ubuntu 18.04 system with Nvidia Driver.
It is necessary to address that nvidia-430 ppa is not accepted by RTX 2070 super. Nvidia has closed the opportunities of nvidia-430 ppa installation. The system automatically gives the Nvidia-440 ppa for installation.
I have the following installation steps
1. Add the Nvidia ppa repo
$ sudo add-apt-repository ppa:graphics-drivers/ppa
2. Update
$ sudo apt-get update
3. Install Nvidia driver
$ sudo apt install nvidia-driver-440
4. Reboot Ubuntu 18.04
$ sudo reboot
5. Check the Driver
$ nvidia-smi
It has still has the problem sometimes.
Please indicate how to solve it completely.
Thanks in advance,
Notes:
While I met the problem with RTX 2060 several month ago, I installed nvidia-driver-430 ppa, it solve the issue. However, while I had RTX 2070 Super this week, I could not be allowed to install nvidia-driver-430 ppa, Therefore, the error occurs again. And it seems that I have no better way to solve it this time. nvidia-driver-440 ppa has a problem with Ubuntu 18.04 but it is forced by Nvidia.
Mike
The ppa is not managed by nvidia but the Ubuntu driver team.
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post. You will have to rename the file ending to something else since the forum software doesn’t accept .gz files (nifty!).
Hi, I had the same problem after I installed nvidia driver on ubuntu 18.04. I followed the above(installing the driver from ppa) and it it seemed to work.
Now 2 new problem arise, It sometimes still shows me a black screen with a single dash(-) . I usually have to restart and it then works. How can I resolved this?
The second problem is that I cannot use with an external display. If I plug an external monitor to ubuntu, my main monitor goes black with the same single dash while the external monitor works. To be able to use my main screen I usually have to run `sudo prime-select intel in which case my external monitor does not work. How do I resolve this
It is a dual boot with windows 10. the laptop specification is Acer Triton 300 with NVIDIA GeForce RTX 3060.
Please Help.
nvidia-bug-report.log.gz (307.6 KB)
Here is the bug-report.log.gz file
You need a newer kernel for your intel igpu which drives the internal screen. Please use the liquorix ppa.
Thanks. It appears it worked. Thanks alot. The external display also works now.
Hello @generix, Here it is
nvidia-bug-report.log.gz (413.3 KB)
I had to edit my earlier post as I am apparently allowed only 3 replies as a new user.
Please create a new nvidia-bug-report.log
@sanusiii Please open a new thread. I can’t notice any problems in your log, what exactly is the issue?
