I have a weird problem. My carrier board is a waveshare one that uses eMMC instead of the SD card. I followed the process described here https://www.waveshare.com/wiki/JETSON-NANO-DEV-KIT#Boot_TF_Card in order to move everything to the SD card. All good and working fine.
However, when trying to apply the device tree changes required for the TC358743, the boot-up process defaults to the original DTS file and ignores my FDT entry. There’s no mention of an error or anything.
0.420699] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
Mar 30 09:26:59 jetson-nano kernel: [ 0.420707] DTB Build time: Apr 20 2022 14:28:59
extlinux.conf:
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
FDT /boot/tegra210-p3448-0002-p3449-0000-b00.dtb
INITRD /boot/initrd
APPEND ${cbootargs} quiet root=/dev/mmcblk1p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
PS: I modified the DTB file to include both the changes required for the TC358743 and the ones described in the guide for using the SD card.
