Jetson Nano with emmc and SD card Reader, SD card not detected
Hi guys!. hope you are doing ok.
I have this jetson nano, I was able to flash the OS using the EMMC, but after booting the SD card is not being recognize.
I suspect of the device tree file, but even enabling the sdhci@700b0400 which is the sdcard reader. still no luck.
I’m using https://developer.nvidia.com/embedded/L4T/r32_Release_v4.4/r32_Release_v4.4-GMC3/T210/Tegra210_Linux_R32.4.4_aarch64.tbz2
as the BSP.
any clue?.
thanks.
Thanks for your reply Wayne.
so If I understand this. I need to download the kernel sources make some changes on the dts file and recompile the kernel? is that so?
Yes, that’s right.
ok, one more question. can I use the source_sync.sh script in order to download the kernel sources? or should I do something different?
Use the tarball from our download center or source_sync.sh should be both fine.
I coudn’t find the sourcer for 4.9 kernel?
Then just use the tarball.
After downloading the source code for 4.9 I got confused about where to found the dts file to modify, there is no tegra210-p3448-0002-p3449-0000-b00.dts file.
Dts files are in the “hardware” directory. Not in k4.9
thanks a lot, I was kind of lost over the directory tree but I think I got it now. :)
