Compare with Devkit, we found the Devkit that connected to PC will show L4T-README in device management on PC when enter into linux OS, but our custom carrier board has no HW device found in device management on PC. Our carrier board is designed with device mode only, that is mean it could be roled as u-disk etc. how to realize that feature?
the snapshot of Devkit in device management as follow:
we use USB3.0 switch for TX/RX switch IC and set the swith into device mode in design, and idealy the carrier board will be like U-disk etc and the PC will recognize it at least for a hardware device or unkown device.
how to make sure NV USB_SS1 is running in host or device mode? The USB0_VBUS_DET_N is switched from high to low when plugged on PC.
