device: NVIDIA DGX Spark / GB10
SYMPTOM
The dashboard (localhost:11000/updates) “July 2026” system-update card never clears, despite repeatedly pressing the green Update button (8+ attempts, each triggering apt upgrade + reboot). Package-layer updates (e.g. the mesa set 25.2.8-0ubuntu0.24.04.2 → .4) DO apply correctly, but the OTA card/badge stays lit permanently.
STATE (nvidia-spark-ota-check)
installed-name: OTA2604 (2026-04-21); is-ota-available: true
summary: match ~96%, 149/155, torn-score 3.9
current stack appears already up to date:
NVIDIA driver 580.178.04, CUDA 13.x, cuda components 13.2 all “match”
kernel 7.0.0-1019-nvidia, DGX 7.6.0 (dgx-release DGX_SWBUILD_VERSION=7.2.3, base 25.04)
REMAINING NON-MATCHING ITEMS (never fixable via Update button / apt)
Two station metapackages are simply never installed:
nvidia-system-station-apps (expected >= 2404.26.01-1, “not found”)
nvidia-system-station-games (expected >= 2404.26.01-1, “not found”)
These exist in the repo but the dashboard flow appears to use apt upgrade semantics,
which will never install never-present packages. On a headless inference server these
station packages are also arguably not desirable.
Firmware/DMI checks can never pass on this unit:
SOCFW SBP:R:2.152.15 != 2.155.11
EC 3.3.2 != 3.5.8
EC Unfused 3.3.2 != 3.5.8
TPM reads literally “SOCTS” != 7.516.1
Supporting evidence that these are not applyable here:
fwupdmgr get-updates --json → { “Devices” : [] } (nothing pending; not even EC/TPM enumerated)
fwupdmgr get-devices: EC and TPM are not present in the device list at all
journal: “gnome-remote-de[1578]: Init TPM credentials failed because No TPM device found,
using GKeyFile as fallback” → no TPM device exists on this board, so the TPM OTA check
can never report a matching version.
ASK
Please confirm whether the dashboard badge logic requires 100% (155/155) DMI match including
station metapackages + EC/TPM checks that fwupd cannot enumerate on GB10; if so the badge is
un-clearable by design on headless DGX Spark units. Note another user (sydikraer, same build:
driver 580.178.04, kernel 7.0.0-1019, DGX 7.6.0, EC 3.3.2, SBP 2.152.15, installed-name OTA2604,
fwupdmgr “no updates available”) has the identical profile.
Attachment: gx10-ota-diag.tar.gz containing
cmd/: full nvidia-spark-ota-check summary (+ -v verbose, torn-score, is-ota-available,
installed-name, mismatches-only), fwupdmgr get-updates/get-devices/version JSONs,
apt upgradable list, apt marks/holds, apt history tail, nvidia-smi, dgx-release, kernel
logs/: dgx-dashboard-admin.log* (current + rotated .1/.2..gz … .6.gz),
dgx-dashboard-service.log* (current + rotated), dgx-dashboard-reboot.log,
journalctl current-boot tail (3000 lines)
Happy to run any further diagnostics you need.
