When I first turned the device the first time and started using it, the device started keep resetting. The device does not even allow me to update the operating system because it keep resetting. What evidence do you want from me?
I have gathered a lot of logs showing lots of issues and incompatibility in the drivers, software and the device:
[Thu Nov 27 22:08:09 2025] NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64 580.82.09 Release Build (dvs-builder@U22-I3-B15-04-1) Fri Aug 29 17:23:11 UTC 2025
[Thu Nov 27 22:08:09 2025] nvidia_fs: no symbol version for nvidia_p2p_dma_unmap_pages
[Thu Nov 27 22:08:09 2025] nvidia_fs: Initializing nvfs driver module
[Thu Nov 27 22:08:09 2025] nvidia_fs: registered correctly with major number 503
[Thu Nov 27 22:08:09 2025] nvidia-fs:warning: error retrieving numa node for device 000f:01:00.0
[Thu Nov 27 22:08:09 2025] nvidia-fs:warning: error retrieving numa node for device 0002:01:00.0
[Thu Nov 27 22:08:09 2025] nvidia-fs:warning: error retrieving numa node for device 0000:01:00.1
[Thu Nov 27 22:08:09 2025] nvidia-fs:warning: error retrieving numa node for device 0007:01:00.0
[Thu Nov 27 22:08:09 2025] nvidia-fs:warning: error retrieving numa node for device 0000:01:00.0
[Thu Nov 27 22:08:09 2025] nvidia-fs:warning: error retrieving numa node for device 0002:01:00.1
[Thu Nov 27 22:08:09 2025] nvidia-fs:warning: error retrieving numa node for device 0004:01:00.0
[Thu Nov 27 22:08:09 2025] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64 580.82.09 Release Build (dvs-builder@U22-I3-B15-04-1) Fri Aug 29 17:10:30 UTC 2025
[Thu Nov 27 22:08:09 2025] [drm] [nvidia-drm] [GPU ID 0x000f0100] Loading driver
[Thu Nov 27 22:08:09 2025] [drm] Initialized nvidia-drm 0.0.0 for 000f:01:00.0 on minor 1
[Thu Nov 27 22:08:12 2025] The NVIDIA GPU driver for AArch64 has not been qualified on this platform
I even tried [link removed]
and created a flash memory to boot the device, once it loads from the flash memory to reset factory the device freezes on this screen.
Nov 27 22:23:17 spark-c31d sudo[6143]: bhajian : TTY=pts/3 ; PWD=/home/bhajian ; USER=root ; COMMAND=/usr/bin/dmesg -T
Nov 27 22:23:17 spark-c31d sudo[6143]: pam_unix(sudo:session): session opened for user root(uid=0) by bhajian(uid=1000)
Nov 27 22:23:17 spark-c31d sudo[6143]: pam_unix(sudo:session): session closed for user root
Nov 27 22:23:17 spark-c31d tracker-miner-fs-3[6147]: (tracker-extract-3:6147): GLib-GIO-WARNING **: 22:23:17.707: Error creating IO channel for /proc/self/mountinfo: Invalid argument (g-io-error-quark, 13)
Nov 27 22:23:22 spark-c31d sudo[6154]:
