I recently noticed that on Windows 11, with the driver 576.40, nvidia-smi displays:
Temperature
GPU Current Temp : 57 C
GPU T.Limit Temp : N/A
GPU Shutdown Temp : 98 C
GPU Slowdown Temp : 95 C
GPU Max Operating Temp : 105 C
GPU Target Temperature : 87 C <-- What I want
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
GPU Power Readings
Average Power Draw : 25.87 W
Instantaneous Power Draw : 25.80 W
Current Power Limit : 105.00 W
Requested Power Limit : 105.00 W
Default Power Limit : 80.00 W
Min Power Limit : 1.00 W
Max Power Limit : 110.00 W
Where the Target Temperature is: 87 C wich means, until 87ºC the gpu will not undervolt or low the freqs to prevent going futher temps.
In the other hand, in my linux arch (cachyos) with cachyos-nvidia drivers: 570.144, nvidia-smi displays:
Temperature
GPU Current Temp : 71 C
GPU Target Temperature : 80 C <-- What I get
GPU Power Readings
Average Power Draw : 44.51 W
Instantaneous Power Draw : 44.79 W
Current Power Limit : 90.00 W
Requested Power Limit : 90.00 W
On windows I had nothing open, in that moment on linux I had cs2 open, but still the “GPU Target Temperature : 80 C” not even changing due to nvidia-powerd wich is on.
For me this is a problem, my laptop has 5200rpm fans, and gets easy above 80ºC without too much efford to it, and due to that, my gpu gets “nerfed” lowering the clock freqs and power consumption.
I have been looking everywhere on the internet if there was a way of changing the parameter “GPU Target Temperature” but I don’t find anything. This really fustrates me, why nvidia drivers on linux concludes the GPU model needs 80ºC barrier while on windows drivers sets it 87ºC.
Is because I need to disable nvidia-powerd and from the boot set the power profile to max or something like that?
And someone knows if in the future the nvidia-smi -gtt 87 command will work?
On both linux and windows “Performance State : P0”
Thank you very much,
Marcos
