Anyone can help with this ?
I’ve been trying different configs accordingly to the documentation (Gst-nvinfer — DeepStream 5.1 Release documentation), but nothing seems to work.
This is the config I’m using:
# Copyright (c) 2019, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
# Following properties are mandatory when engine files are not specified:
# int8-calib-file(Only in INT8), model-file-format
# Caffemodel mandatory properties: model-file, proto-file, output-blob-names
# UFF: uff-file, input-dims, uff-input-blob-name, output-blob-names
# ONNX: onnx-file
# Mandatory properties for detectors:
# num-detected-classes
# Optional properties for detectors:
# cluster-mode(Default=Group Rectangles), interval(Primary mode only, Default=0)
# custom-lib-path,
# parse-bbox-func-name
# Mandatory properties for classifiers:
# classifier-threshold, is-classifier
# Optional properties for classifiers:
# classifier-async-mode(Secondary mode only, Default=false)
# Optional properties in secondary mode:
# operate-on-gie-id(Default=0), operate-on-class-ids(Defaults to all classes),
# input-object-min-width, input-object-min-height, input-object-max-width,
# input-object-max-height
# Following properties are always recommended:
# batch-size(Default=1)
# Other optional properties:
# net-scale-factor(Default=1), network-mode(Default=0 i.e FP32),
# model-color-format(Default=0 i.e. RGB) model-engine-file, labelfile-path,
# mean-file, gie-unique-id(Default=0), offsets, process-mode (Default=1 i.e. primary),
# custom-lib-path, network-mode(Default=0 i.e FP32)
# The values in the config file are overridden by values set through GObject
# properties.
[property]
gpu-id=0
net-scale-factor=0.8
model-color-format=0
uff-file=../models/lane_segmentationLowerLoss-resnet34_384x384.uff
model-engine-file=../models/lane_segmentationLowerLoss-resnet34_384x384.uff_b1_gpu0_fp16.engine
infer-dims=3;384;384
uff-input-order=0
uff-input-blob-name=data
batch-size=1
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
num-detected-classes=1
interval=0
gie-unique-id=1
network-type=2
output-blob-names=final_conv/BiasAdd
# output-blob-names=sigmoid/Sigmoid
segmentation-threshold=0.0
# scaling-filter=1
scaling-compute-hw=1
