Greetings,
It seems that I have found the source of the bottleneck of the performance. I had minor modified the python deepstream app named segmask.py mainly in the function def tiler_sink_pad_buffer_probe(pad, info, u_data).
deepstream_segmask.py
#!/usr/bin/env python3
SPDX-FileCopyrightText: Copyright (c) 2020-2022 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
SPDX-License-Identifier: Apache-2.0
Licensed under the Apache License, Version 2.0 (the “License”);
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an “AS IS” BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
import sys
from syslog import LOG_WARNING
sys.path.append(‘../’)
import gi
import configparser
gi.require_version(‘Gst’, ‘1.0’)
from gi.repository import GLib, Gst
from ctypes import *
import time
import sys
import math
import platform
from common.is_aarch_64 import is_aarch64
from common.bus_call import bus_call
from common.FPS import PERF_DATA
import numpy as np
import pyds
import cv2
import os
import os.path
from os import path
import argparse
try:
import debugpy
except:
debugpy = None
import json
import socket
Create a socket
sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
sock.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
Connect to the other script
host = ‘localhost’ # Replace with the host IP address
port = 12345 # Replace with the desired port number
sock.connect((host, port))
perf_data = None
MAX_DISPLAY_LEN = 64
MUXER_OUTPUT_WIDTH = 1344
MUXER_OUTPUT_HEIGHT = 832
MUXER_BATCH_TIMEOUT_USEC = 4000000
TILED_OUTPUT_WIDTH = 1344
TILED_OUTPUT_HEIGHT = 832
GST_CAPS_FEATURES_NVMM = “memory:NVMM”
tiler_sink_pad_buffer_probe will extract metadata received on tiler sink pad
and re-size and binarize segmentation mask array to save to image
def tiler_sink_pad_buffer_probe(pad, info, u_data):
frame_number = 0
num_rects = 0
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.NvDsFrameMeta.cast()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
except StopIteration:
break
frame_number = frame_meta.frame_num
l_obj = frame_meta.obj_meta_list
num_rects = frame_meta.num_obj_meta
is_first_obj = True
save_image = False
obj_number = 0
black_image = np.zeros((832, 1344), dtype=np.uint8)
cv2.imwrite("/home/administrator/black_frame.jpg", black_image)
while l_obj is not None:
try:
# Casting l_obj.data to pyds.NvDsObjectMeta
obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
break
rectparams = obj_meta.rect_params # Retrieve rectparams for re-sizing mask to correct dims
maskparams = obj_meta.mask_params # Retrieve maskparams
print(rectparams.left, rectparams.top)
mask_image = 255 * np.ones((int(rectparams.height),int(rectparams.width)), np.uint8)
cv2.imwrite("/home/administrator/white_frame.jpg", mask_image)
x = int(rectparams.left)
y = int(rectparams.top)
black_image[y:y + int(rectparams.height),x:x + int(rectparams.width)] = mask_image
upper_part_LWA = black_image[0:180,640:960]
middle_part_LWA = black_image[180:360,640:960]
lower_part_LWA = black_image[360:540,640:960]
cv2.imwrite("/home/administrator/yolo_upper.jpg", upper_part_LWA) # Save mask to image
cv2.imwrite("/home/administrator/yolo_middle.jpg", middle_part_LWA) # Save mask to image
cv2.imwrite("/home/administrator/yolo_lower.jpg", lower_part_LWA) # Save mask to image
count_upper = np.count_nonzero(upper_part_LWA == 255)
count_middle = np.count_nonzero(middle_part_LWA == 255)
count_lower = np.count_nonzero(lower_part_LWA == 255)
print("Total white pixels in upper part: ",count_upper)
print("Total white pixels in middle part: ",count_middle)
print("Total white pixels in lower part: ",count_lower)
print("Percentage in upper part ",(count_upper/upper_part_LWA.size)*100)
print("Percentage in middle part ",(count_middle/middle_part_LWA.size)*100)
print("Percentage in lower part ",(count_lower/lower_part_LWA.size)*100)
# Create a dictionary to store the values
data = {
'upper_part': (count_upper/upper_part_LWA.size)*100,
'middle_part': (count_middle/middle_part_LWA.size)*100,
'lower_part': (count_lower/lower_part_LWA.size)*100
# Serialize the data to JSON
json_data = json.dumps(data)
# Send the JSON data over the socket
sock.sendall(json_data.encode())
#mask_image = resize_mask(maskparams, math.floor(rectparams.width), math.floor(rectparams.height)) # Get resized mask array
#print(rectparams,maskparams)
#black_image[y:y + int(rectparams.height),x:x + int(rectparams.width)] = mask_image
#cv2.imwrite("/home/administrator/frame.jpg", black_image)
#print(mask_image)
#if is_first_obj and frame_number % 30 == 0:
# print("mpika edw")
# is_first_obj = False
# rectparams = obj_meta.rect_params # Retrieve rectparams for re-sizing mask to correct dims
# maskparams = obj_meta.mask_params # Retrieve maskparams
# mask_image = resize_mask(maskparams, math.floor(rectparams.width), math.floor(rectparams.height)) # Get resized mask array
# x = int(rectparams.left)
# y = int(rectparams.top)
# black_image[y:y + int(rectparams.height),x:x + int(rectparams.width)] = mask_image
#img_path = "{}/stream_{}/frame_{}.jpg".format(folder_name, frame_meta.pad_index, frame_number)
#cv2.imwrite(img_path, mask_image) # Save mask to image
try:
l_obj = l_obj.next
obj_number += 1
break
cv2.imwrite("/home/administrator/black_frame_masks.jpg", black_image)
print("Frame Number=", frame_number, "Number of Objects=", num_rects)
# update frame rate through this probe
stream_index = "stream{0}".format(frame_meta.pad_index)
global perf_data
perf_data.update_fps(stream_index)
try:
l_frame = l_frame.next
break
return Gst.PadProbeReturn.OK
def clip(val, low, high):
if val < low:
return low
elif val > high:
return high
else:
return val
Resize and binarize mask array for interpretable segmentation mask
def resize_mask(maskparams, target_width, target_height):
src = maskparams.get_mask_array() # Retrieve mask array
dst = np.empty((target_height, target_width), src.dtype) # Initialize array to store re-sized mask
original_width = maskparams.width
original_height = maskparams.height
ratio_h = float(original_height) / float(target_height)
ratio_w = float(original_width) / float(target_width)
threshold = maskparams.threshold
channel = 1
# Resize from original width/height to target width/height
for y in range(target_height):
for x in range(target_width):
print("mpika edw")
x0 = float(x) * ratio_w
y0 = float(y) * ratio_h
left = int(clip(math.floor(x0), 0.0, float(original_width - 1.0)))
top = int(clip(math.floor(y0), 0.0, float(original_height - 1.0)))
right = int(clip(math.ceil(x0), 0.0, float(original_width - 1.0)))
bottom = int(clip(math.ceil(y0), 0.0, float(original_height - 1.0)))
for c in range(channel):
# H, W, C ordering
# Note: lerp is shorthand for linear interpolation
left_top_val = float(src[top * (original_width * channel) + left * (channel) + c])
right_top_val = float(src[top * (original_width * channel) + right * (channel) + c])
left_bottom_val = float(src[bottom * (original_width * channel) + left * (channel) + c])
right_bottom_val = float(src[bottom * (original_width * channel) + right * (channel) + c])
top_lerp = left_top_val + (right_top_val - left_top_val) * (x0 - left)
bottom_lerp = left_bottom_val + (right_bottom_val - left_bottom_val) * (x0 - left)
lerp = top_lerp + (bottom_lerp - top_lerp) * (y0 - top)
if (lerp < threshold): # Binarize according to threshold
dst[y,x] = 0
else:
dst[y,x] = 255
return dst
def cb_newpad(decodebin, decoder_src_pad, data):
print(“In cb_newpad\n”)
caps = decoder_src_pad.get_current_caps()
gststruct = caps.get_structure(0)
gstname = gststruct.get_name()
source_bin = data
features = caps.get_features(0)
# Need to check if the pad created by the decodebin is for video and not
# audio.
if (gstname.find("video") != -1):
# Link the decodebin pad only if decodebin has picked nvidia
# decoder plugin nvdec_*. We do this by checking if the pad caps contain
# NVMM memory features.
if features.contains("memory:NVMM"):
# Get the source bin ghost pad
bin_ghost_pad = source_bin.get_static_pad("src")
if not bin_ghost_pad.set_target(decoder_src_pad):
sys.stderr.write("Failed to link decoder src pad to source bin ghost pad\n")
else:
sys.stderr.write(" Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy, Object, name, user_data):
print(“Decodebin child added:”, name, “\n”)
if name.find(“decodebin”) != -1:
Object.connect(“child-added”, decodebin_child_added, user_data)
if "source" in name:
source_element = child_proxy.get_by_name("source")
if source_element.find_property('drop-on-latency') != None:
Object.set_property("drop-on-latency", True)
def create_source_bin(index, uri):
print(“Creating source bin”)
# Create a source GstBin to abstract this bin's content from the rest of the
# pipeline
bin_name = "source-bin-%02d" % index
print(bin_name)
nbin = Gst.Bin.new(bin_name)
if not nbin:
sys.stderr.write(" Unable to create source bin \n")
# Source element for reading from the uri.
# We will use decodebin and let it figure out the container format of the
# stream and the codec and plug the appropriate demux and decode plugins.
uri_decode_bin = Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
if not uri_decode_bin:
sys.stderr.write(" Unable to create uri decode bin \n")
# We set the input uri to the source element
uri_decode_bin.set_property("uri", uri)
# Connect to the "pad-added" signal of the decodebin which generates a
# callback once a new pad for raw data has beed created by the decodebin
uri_decode_bin.connect("pad-added", cb_newpad, nbin)
uri_decode_bin.connect("child-added", decodebin_child_added, nbin)
# We need to create a ghost pad for the source bin which will act as a proxy
# for the video decoder src pad. The ghost pad will not have a target right
# now. Once the decode bin creates the video decoder and generates the
# cb_newpad callback, we will set the ghost pad target to the video decoder
# src pad.
Gst.Bin.add(nbin, uri_decode_bin)
bin_pad = nbin.add_pad(Gst.GhostPad.new_no_target("src", Gst.PadDirection.SRC))
if not bin_pad:
sys.stderr.write(" Failed to add ghost pad in source bin \n")
return None
return nbin
def main(stream_paths, output_folder):
global perf_data
perf_data = PERF_DATA(len(stream_paths))
number_sources = len(stream_paths)
global folder_name
folder_name = output_folder
if path.exists(folder_name):
sys.stderr.write(“The output folder %s already exists. Please remove it first.\n” % folder_name)
sys.exit(1)
os.mkdir(folder_name)
print("Frames will be saved in ", folder_name)
# Standard GStreamer initialization
Gst.init(None)
# Create gstreamer elements */
# Create Pipeline element that will form a connection of other elements
print("Creating Pipeline \n ")
pipeline = Gst.Pipeline()
is_live = False
if not pipeline:
sys.stderr.write(" Unable to create Pipeline \n")
print("Creating streammux \n ")
# Create nvstreammux instance to form batches from one or more sources.
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
sys.stderr.write(" Unable to create NvStreamMux \n")
pipeline.add(streammux)
for i in range(number_sources):
os.mkdir(folder_name + “/stream_” + str(i))
print("Creating source_bin ", i, " \n ")
uri_name = stream_paths[i]
if uri_name.find("rtsp://") == 0:
is_live = True
source_bin = create_source_bin(i, uri_name)
if not source_bin:
sys.stderr.write("Unable to create source bin \n")
pipeline.add(source_bin)
padname = "sink_%u" % i
sinkpad = streammux.get_request_pad(padname)
if not sinkpad:
sys.stderr.write("Unable to create sink pad bin \n")
srcpad = source_bin.get_static_pad("src")
if not srcpad:
sys.stderr.write("Unable to create src pad bin \n")
srcpad.link(sinkpad)
print("Creating Pgie \n ")
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
if not pgie:
sys.stderr.write(" Unable to create pgie \n")
print("Creating tiler \n ")
tiler = Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
if not tiler:
sys.stderr.write(" Unable to create tiler \n")
print("Creating nvvidconv \n ")
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
if not nvvidconv:
sys.stderr.write(" Unable to create nvvidconv \n")
print("Creating nvosd \n ")
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
sys.stderr.write(" Unable to create nvosd \n")
if is_aarch64():
print("Creating nv3dsink \n")
sink = Gst.ElementFactory.make("nv3dsink", "nv3d-sink")
if not sink:
sys.stderr.write(" Unable to create nv3dsink \n")
else:
print("Creating EGLSink \n")
sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
if not sink:
sys.stderr.write(" Unable to create egl sink \n")
if is_live:
print("Atleast one of the sources is live")
streammux.set_property('live-source', 1)
streammux.set_property('width', 1344)
streammux.set_property('height', 832)
streammux.set_property('batch-size', number_sources)
streammux.set_property('batched-push-timeout', 4000000)
pgie.set_property('config-file-path', "dstest_segmask_config.txt")
pgie_batch_size = pgie.get_property("batch-size")
if (pgie_batch_size != number_sources):
print("WARNING: Overriding infer-config batch-size", pgie_batch_size, " with number of sources ",
number_sources, " \n")
pgie.set_property("batch-size", number_sources)
tiler_rows = int(math.sqrt(number_sources))
tiler_columns = int(math.ceil((1.0 * number_sources) / tiler_rows))
tiler.set_property("rows", tiler_rows)
tiler.set_property("columns", tiler_columns)
tiler.set_property("width", TILED_OUTPUT_WIDTH)
tiler.set_property("height", TILED_OUTPUT_HEIGHT)
nvosd.set_property("display_mask", True) # Note: display-mask is supported only for process-mode=0 (CPU)
nvosd.set_property('process_mode', 0)
sink.set_property("sync", 0)
sink.set_property("qos", 0)
queue1=Gst.ElementFactory.make("queue","queue1")
queue2=Gst.ElementFactory.make("queue","queue2")
queue3=Gst.ElementFactory.make("queue","queue3")
queue4=Gst.ElementFactory.make("queue","queue4")
queue5=Gst.ElementFactory.make("queue","queue5")
pipeline.add(queue1)
pipeline.add(queue2)
pipeline.add(queue3)
pipeline.add(queue4)
pipeline.add(queue5)
print("Adding elements to Pipeline \n")
pipeline.add(pgie)
pipeline.add(tiler)
pipeline.add(nvvidconv)
pipeline.add(nvosd)
pipeline.add(sink)
print("Linking elements in the Pipeline \n")
streammux.link(queue1)
queue1.link(pgie)
pgie.link(queue2)
queue2.link(tiler)
tiler.link(queue3)
queue3.link(nvvidconv)
nvvidconv.link(queue4)
queue4.link(nvosd)
nvosd.link(queue5)
queue5.link(sink)
# create an event loop and feed gstreamer bus mesages to it
loop = GLib.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message", bus_call, loop)
tiler_sink_pad = tiler.get_static_pad("sink")
if not tiler_sink_pad:
sys.stderr.write(" Unable to get src pad \n")
else:
tiler_sink_pad.add_probe(Gst.PadProbeType.BUFFER, tiler_sink_pad_buffer_probe, 0)
# perf callback function to print fps every 5 sec
GLib.timeout_add(5000, perf_data.perf_print_callback)
# List the sources
print("Now playing...")
for i, source in enumerate(stream_paths):
print(i, ": ", source)
print("Starting pipeline \n")
# start play back and listed to events
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
# cleanup
print("Exiting app\n")
pipeline.set_state(Gst.State.NULL)
def parse_args():
parser = argparse.ArgumentParser(prog=“deepstream_segmask.py”,
description=“deepstream-segmask takes multiple URI streams as input”
" and re-sizes and binarizes segmentation mask arrays to save to image")
parser.add_argument(
“-i”,
“–input”,
help=“Path to input streams”,
nargs=“+”,
metavar=“URIs”,
default=[“a”],
required=True,
“-o”,
“–output”,
metavar=“output_folder_name”,
default=“out”,
help=“Name of folder to output mask images”,
args = parser.parse_args()
stream_paths = args.input
output_folder = args.output
return stream_paths, output_folder
if name == ‘main’:
stream_paths, output_folder = parse_args()
sys.exit(main(stream_paths, output_folder))
It seems that the bottleneck i mainly cased from the image_resize, when i am using the peoplesegnet the image resize does not “cost” very much since the dimensions of the destination image is smaller(propably 3030 pixels), but when i resize the image using my model costs because the destination image is much bigger(19201080). I am not very sure that this is the main reason but i am sure that the problem is caused in the image resize function.
Lastly the performace was measured based on from common.FPS import PERF_DATA of the code
