Differential-drive + caster under-rotates: achieves only ~50% of commanded yaw at low ω — invariant to friction, drive gain, contact shape
5.1.0
Operating System
Ubuntu 24.04
Ubuntu 22.04
GPU Information
  • Model:RTX 5060
  • Driver Version:580.159.03
Topic Description
I’m trying to build a Digital Twin for my mobile robot, facing the following problem while trying to simulate realistic differential drive behavior
Environment
▎ - Isaac Sim 5.1; CPU dynamics (enableGPUDynamics=False)
▎ - Scene: solverType=TGS, frictionType=patch, frictionCorrelationDistance=0.025,
▎ frictionOffsetThreshold=0.04, enableStabilization=True, collisionSystem=PCM, enableCCD=True, timeStepsPerSecond=60
▎ Robot (URDF import): differential drive — two rear drive wheels (r=0.107 m, mount track 0.618 m)
▎ + one passive centered front caster (r=0.0625 m, trail ~0.042 m, carries ~48% of weight). Mass
▎ 400 kg, base Izz 41 kg·m² (both validated against CAD). Articulation: WheeledRobot +
▎ DifferentialController; each physics step I call
▎ articulation_controller.apply_action(ArticulationAction(joint_velocities=[L,R],
▎ joint_indices=wheel_dofs)).
▎ Drive config: velocity mode (stiffness=0), damping=500 (verified at runtime via get_gains()),
▎ maxForce=400 N·m, joint velocity limit 20 rad/s. Solver iters: position 32, velocity 8.
▎ physics_dt=1/60.
▎ Problem: commanded angular velocity is badly under-achieved while linear velocity tracks ~95%.
▎ Body yaw measured via get_angular_velocity()[2]:
▎ - In-place rotation: achieved/commanded = 0.52 @ ω=0.2, 0.75 @ ω=0.5, 0.79 @ ω= 1.0 (ratio improves with speed).
▎ - Gentle arc (v=0.2, ω=0.2): body yaws ~0.10 rad/s (~52%).
▎ - The physical robot tracks commanded yaw accurately.
▎ Wheel-level telemetry (commanded vs actual joint velocity):
▎ - In-place, low ω: wheels do reach their commanded ± speeds, but the body still under-rotates → wheels are slipping/scrubbing in place.
▎ - In arcs: the outer wheel never reaches its commanded speed (e.g. cmd 2.45 rad/s, actual
▎ ~1.6–1.8 — sits at body forward-rolling speed); inner wheel tracks.
▎ Already ruled out (no measurable change to the yaw deficit):
▎ - Caster wheel μ: 0.8 → 0.2 → 0.02 (near-frictionless)
▎ - Drive-tyre collider width: cylinder height 0.089 → 0.02 m
▎ - Drive wheel collider shape: cylinder → sphere (point contact)
▎ - Drive velocity gain kd: 100 → 500 → 1500 (confirmed applied)
▎ - Drive wheel μ: 0.8 → 1.5
▎ - Drive maxForce: 200 → 400 N·m
▎ - Mass/inertia validated against CAD
▎ Questions:
▎ 1. With wheels tracking their velocity targets but the body under-rotating (in-place), and the outer wheel failing to reach target (arcs) — what governs this slip, independent of friction/contact/gain?
▎ 2. The ratio improving with command magnitude looks stiction-like — could enableStabilization and/or patch friction (frictionCorrelationDistance) be damping low-speed yaw? Recommended scene settings for a velocity-driven wheeled robot?
▎ Can share URDF/USD and a minimal repro. I spent a lot of time trying to get to the bottom of this, i might have missed something fundamental. Kindly help me out in resolving this problem, any new insights are appreciated.
Hi @kbr9112014,
Thanks for the posting this issue. Here are some pointers:
A couple of directions worth checking:
  • Low-speed contact/solver regime.
Ratio improves with speed, invariant to the friction coefficient
Could be an artifact of the solvers residuals. Try raising the physics rate to 120–240 Hz and bumping physxArticulation:solverPositionIterationCount (e.g. 32+).
  • Confirm the slip by logging each drive wheel’s contact-point lateral
    velocity during the turn.
Could you share the URDF + minimal repro you mentioned? With your exact
masses/inertia (Izz=41), COM, and caster geometry if possible — a hand-built model is too sensitive to mass distribution to match your numbers without it.
Hello!
We noticed that this topic hasn’t received any recent updates from anyone reporting this issue, so we are closing it for now to help keep the forum organized.
If you are still experiencing this issue or have related questions, please create a GitHub Discussion or Issue in the Isaac Sim repository and include a link to this topic along with updated details. Mentioning or linking to this original topic provides helpful context and makes it easier for others to assist you.
Best regards,
