Differentiation between legacy and new versions of the Jetson Orin NX module
We are planning to use the Orin NX in 40 Watts MaxN mode. In the datasheet it is mentioned that legacy module do not support MaxN mode.
Could you please confirm whether the new and legacy Orin NX modules have different part numbers?
Also, could you share the specific SOM part number for the module that supports 40W MaxN mode?
Thank you
That super mode is to do the configuration by SW method, not HW changes.
Please be sure your board design can meet the power watt requirement.
