How can I change the Orin NX's power mode?
I changed my Orin NX’s power mode to 25W(ID:2), and I tried to change again to MAXN mode, but it didn’t work.
And this is the error code
v$ sudo nvpmodel -m 0
NVPM ERROR: Error opening /sys/devices/system/cpu/cpu6/online: 2
NVPM ERROR: failed to write PARAM CPU_ONLINE: ARG CORE_6: PATH: /sys/devices/system/cpu/cpu6/online VAL: 1
NVPM ERROR: failed to set power mode!
NVPM ERROR: optMask is 1, no request for power mode
$ nvpmodel -q
NV Power Mode: 25W
3
NVPM ERROR: failed to read PARAM CPU_ONLINE: ARG CORE_6: PATH /sys/devices/system/cpu/cpu6/online
NVPM ERROR: Error opening /sys/devices/system/cpu/cpu7/online: 2
NVPM ERROR: failed to read PARAM CPU_ONLINE: ARG CORE_7: PATH /sys/devices/system/cpu/cpu7/online
NVPM ERROR: Error opening /sys/kernel/nvpmodel_emc_cap/emc_iso_cap: 13
NVPM ERROR: failed to read PARAM EMC: ARG MAX_FREQ: PATH /sys/kernel/nvpmodel_emc_cap/emc_iso_cap
Hi highsoul1227,
Are you using the devkit or custom board for Orin NX?
Could you run MAXN mode before?
You should use sudo for this command.
$ sudo nvpmodel -q
Please share the /etc/nvpmodel.conf from your board.
I used MAXN mode before.
And I tried to use command with sudo of course.
Below is the $cat /etc/nvpmodel.conf
$ cat /etc/nvpmodel.conf
# Copyright (c) 2021-2022, NVIDIA CORPORATION.  All rights reserved.
# NVIDIA CORPORATION and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto.  Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA CORPORATION is strictly prohibited.
# FORMAT:
# < PARAM TYPE=PARAM_TYPE NAME=PARAM_NAME >
# ARG1_NAME ARG1_PATH_VAL
# ARG2_NAME ARG2_PATH_VAL
# This starts a section of PARAM definitions, in which each line
# has the syntax below:
# ARG_NAME ARG_PATH_VAL
# ARG_NAME is a macro name for argument value ARG_PATH_VAL.
# PARAM_TYPE can be FILE, or CLOCK.
# < POWER_MODEL ID=id_num NAME=mode_name >
# PARAM1_NAME ARG11_NAME ARG11_VAL
# PARAM1_NAME ARG12_NAME ARG12_VAL
# PARAM2_NAME ARG21_NAME ARG21_VAL
# This starts a section of POWER_MODEL configurations, followed by
# lines with parameter settings as the format below:
# PARAM_NAME ARG_NAME ARG_VAL
# PARAM_NAME and ARG_NAME are defined in PARAM definition sections.
# ARG_VAL is an integer for PARAM_TYPE of CLOCK, and -1 is taken
# as INT_MAX. ARG_VAL is a string for PARAM_TYPE of FILE.
# This file must contain at least one POWER_MODEL section.
# < PM_CONFIG DEFAULT=default_mode >
# This is a mandatory section to specify one of the defined power
# model as the default.
# PARAM DEFINITIONS       #
< PARAM TYPE=FILE NAME=CPU_ONLINE >
CORE_0 /sys/devices/system/cpu/cpu0/online
CORE_1 /sys/devices/system/cpu/cpu1/online
CORE_2 /sys/devices/system/cpu/cpu2/online
CORE_3 /sys/devices/system/cpu/cpu3/online
CORE_4 /sys/devices/system/cpu/cpu4/online
CORE_5 /sys/devices/system/cpu/cpu5/online
CORE_6 /sys/devices/system/cpu/cpu6/online
CORE_7 /sys/devices/system/cpu/cpu7/online
< PARAM TYPE=FILE NAME=FBP_POWER_GATING >
FBP_PG_MASK /sys/devices/gpu.0/fbp_pg_mask
< PARAM TYPE=FILE NAME=TPC_POWER_GATING >
TPC_PG_MASK /sys/devices/gpu.0/tpc_pg_mask
< PARAM TYPE=FILE NAME=GPU_POWER_CONTROL_ENABLE >
GPU_PWR_CNTL_EN /sys/devices/gpu.0/power/control
< PARAM TYPE=FILE NAME=GPU_POWER_CONTROL_DISABLE >
GPU_PWR_CNTL_DIS /sys/devices/gpu.0/power/control
< PARAM TYPE=CLOCK NAME=CPU_A78_0 >
FREQ_TABLE /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
MAX_FREQ /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
MIN_FREQ /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
FREQ_TABLE_KNEXT /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
MAX_FREQ_KNEXT /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
MIN_FREQ_KNEXT /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
< PARAM TYPE=CLOCK NAME=CPU_A78_1 >
FREQ_TABLE /sys/devices/system/cpu/cpu4/cpufreq/scaling_available_frequencies
MAX_FREQ /sys/devices/system/cpu/cpu4/cpufreq/scaling_max_freq
MIN_FREQ /sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq
FREQ_TABLE_KNEXT /sys/devices/system/cpu/cpu4/cpufreq/scaling_available_frequencies
MAX_FREQ_KNEXT /sys/devices/system/cpu/cpu4/cpufreq/scaling_max_freq
MIN_FREQ_KNEXT /sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq
< PARAM TYPE=CLOCK NAME=GPU >
FREQ_TABLE /sys/devices/17000000.ga10b/devfreq/17000000.ga10b/available_frequencies
MAX_FREQ /sys/devices/17000000.ga10b/devfreq/17000000.ga10b/max_freq
MIN_FREQ /sys/devices/17000000.ga10b/devfreq/17000000.ga10b/min_freq
FREQ_TABLE_KNEXT /sys/devices/17000000.ga10b/devfreq_dev/available_frequencies
MAX_FREQ_KNEXT /sys/devices/17000000.ga10b/devfreq_dev/max_freq
MIN_FREQ_KNEXT /sys/devices/17000000.ga10b/devfreq_dev/min_freq
<PARAM TYPE=CLOCK NAME=EMC >
MAX_FREQ /sys/kernel/nvpmodel_emc_cap/emc_iso_cap
MAX_FREQ_KNEXT /sys/kernel/nvpmodel_emc_cap/emc_iso_cap
< PARAM TYPE=CLOCK NAME=DLA0_CORE >
MAX_FREQ /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_core
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_core
< PARAM TYPE=CLOCK NAME=DLA0_FALCON >
MAX_FREQ /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_falcon
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_falcon
< PARAM TYPE=CLOCK NAME=DLA1_CORE >
MAX_FREQ /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_core
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_core
< PARAM TYPE=CLOCK NAME=DLA1_FALCON >
MAX_FREQ /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_falcon
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_falcon
< PARAM TYPE=CLOCK NAME=PVA0_VPS >
MAX_FREQ /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_vps
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_vps
< PARAM TYPE=CLOCK NAME=PVA0_AXI >
MAX_FREQ /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_cpu_axi
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_cpu_axi
# POWER_MODEL DEFINITIONS #
# MAXN is the NONE power model to release all constraints
< POWER_MODEL ID=0 NAME=MAXN >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 1
CPU_ONLINE CORE_5 1
CPU_ONLINE CORE_6 1
CPU_ONLINE CORE_7 1
FBP_POWER_GATING FBP_PG_MASK 2
TPC_POWER_GATING TPC_PG_MASK 240
GPU_POWER_CONTROL_ENABLE GPU_PWR_CNTL_EN on
CPU_A78_0 MIN_FREQ 729600
CPU_A78_0 MAX_FREQ -1
CPU_A78_1 MIN_FREQ 729600
CPU_A78_1 MAX_FREQ -1
GPU MIN_FREQ 0
GPU MAX_FREQ -1
GPU_POWER_CONTROL_DISABLE GPU_PWR_CNTL_DIS auto
EMC MAX_FREQ 0
DLA0_CORE MAX_FREQ -1
DLA1_CORE MAX_FREQ -1
DLA0_FALCON MAX_FREQ -1
DLA1_FALCON MAX_FREQ -1
PVA0_VPS MAX_FREQ -1
PVA0_AXI MAX_FREQ -1
< POWER_MODEL ID=1 NAME=10W >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 0
CPU_ONLINE CORE_5 0
CPU_ONLINE CORE_6 0
CPU_ONLINE CORE_7 0
TPC_POWER_GATING TPC_PG_MASK 252
CPU_A78_0 MAX_FREQ 1190400
GPU MIN_FREQ 0
GPU MAX_FREQ 612000000
EMC MAX_FREQ 2133000000
DLA0_CORE MAX_FREQ 153600000
DLA1_CORE MAX_FREQ 115000000
DLA0_FALCON MAX_FREQ 115000000
DLA1_FALCON MAX_FREQ 115000000
PVA0_VPS MAX_FREQ 115000000
PVA0_AXI MAX_FREQ 115000000
< POWER_MODEL ID=2 NAME=15W >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 0
CPU_ONLINE CORE_5 0
CPU_ONLINE CORE_6 0
CPU_ONLINE CORE_7 0
CPU_A78_0 MAX_FREQ 1651200
GPU MIN_FREQ 0
EMC MAX_FREQ 0
DLA0_CORE MAX_FREQ 614400000
DLA1_CORE MAX_FREQ 614400000
DLA0_FALCON MAX_FREQ 294400000
DLA1_FALCON MAX_FREQ 294400000
< POWER_MODEL ID=3 NAME=25W >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 1
CPU_ONLINE CORE_5 1
CPU_ONLINE CORE_6 1
CPU_ONLINE CORE_7 1
CPU_A78_0 MAX_FREQ 1497600
CPU_A78_1 MAX_FREQ 1497600
GPU MIN_FREQ 0
GPU MAX_FREQ 408000000
EMC MAX_FREQ 0
PVA0_VPS MAX_FREQ 512000000
PVA0_AXI MAX_FREQ 358400000
# mandatory section to configure the default power mode
< PM_CONFIG DEFAULT=2 >
Please also share the result of the following command on your board.
$ cat /etc/nv_boot_control.conf
Umm… I bought Seeed studio’s reComputer J4011-Edge model(Jetson Orin NX 8GB)
https://www.seeedstudio.com/reComputer-J4011-p-5585.html
TNSPEC 3767-300-0001-N.2-1-0-recomputer-orin-
COMPATIBLE_SPEC 3767–0001–1–recomputer-orin-
TEGRA_LEGACY_UPDATE false
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_EMMC_ONLY false
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
It seems you are using custom carrier board(from Seeed Studio) with Orin NX 8G module (SKU 0001).
It has only 6 cores CPU (cpu0 to cpu5) so that it reporting the following error.
Could you replace /etc/nvpmodel.conf from your board with the following configuration file?
nvpmodel_p3767_0001.conf (7.6 KB)
and run sudo nvpmodel -m 0 again to apply MAXN mode.
