I’m trying to configure the /etc/nvpmodel.conf, or /etc/nvpmodel/nvpmodel_p3767_0000.conf for the Orin NX 16GB, such that it selects the “MAXN” mode on reboot by setting < PM_CONFIG DEFAULT=0 >. However when i reboot i get:
# nvpmodel -q --verbose
NVPM VERB: Config file: /etc/nvpmodel.conf
NVPM VERB: parsing done for /etc/nvpmodel.conf
NVPM VERB: Using default settings.
NVPM WARN: power mode is not set!
I have deleted the “/var/lib/nvpmodel/status” file as explained here
It also seems the power model is missing from jetson_clocks --show output:
# jetson_clocks --show
SOC family:tegra234 Machine:NVIDIA Orin NX Developer Kit
Online CPUs: 0-7
cpu0: Online=1 Governor=performance MinFreq=729600 MaxFreq=1984000 CurrentFreq=1984000 IdleStates: WFI=1 c7=1
cpu1: Online=1 Governor=performance MinFreq=729600 MaxFreq=1984000 CurrentFreq=1984000 IdleStates: WFI=1 c7=1
cpu2: Online=1 Governor=performance MinFreq=729600 MaxFreq=1984000 CurrentFreq=1984000 IdleStates: WFI=1 c7=1
cpu3: Online=1 Governor=performance MinFreq=729600 MaxFreq=1984000 CurrentFreq=1984000 IdleStates: WFI=1 c7=1
cpu4: Online=1 Governor=performance MinFreq=729600 MaxFreq=1984000 CurrentFreq=1984000 IdleStates: WFI=1 c7=1
cpu5: Online=1 Governor=performance MinFreq=729600 MaxFreq=1984000 CurrentFreq=1984000 IdleStates: WFI=1 c7=1
cpu6: Online=1 Governor=performance MinFreq=729600 MaxFreq=1984000 CurrentFreq=1984000 IdleStates: WFI=1 c7=1
cpu7: Online=1 Governor=performance MinFreq=729600 MaxFreq=1984000 CurrentFreq=1984000 IdleStates: WFI=1 c7=1
GPU MinFreq=306000000 MaxFreq=918000000 CurrentFreq=306000000
EMC MinFreq=204000000 MaxFreq=3199000000 CurrentFreq=2133000000 FreqOverride=0
DLA0_CORE: Online=1 MinFreq=0 MaxFreq=18446744073709551615 CurrentFreq=614400000
DLA0_FALCON: Online=1 MinFreq=0 MaxFreq=18446744073709551615 CurrentFreq=294400000
DLA1_CORE: Online=1 MinFreq=0 MaxFreq=18446744073709551615 CurrentFreq=614400000
DLA1_FALCON: Online=1 MinFreq=0 MaxFreq=18446744073709551615 CurrentFreq=294400000
PVA0_VPS0: Online=1 MinFreq=0 MaxFreq=18446744073709551615 CurrentFreq=704000000
PVA0_AXI: Online=1 MinFreq=0 MaxFreq=18446744073709551615 CurrentFreq=486400000
FAN Dynamic Speed control=active hwmon3_pwm1=128
Usually there’s a NV Power Mode: MAXN at the bottom. It also seems to have enabled all cpus by default, which is odd.
The Orin NX has been flashed with the basic rootfs , with some changes to the default nvidia-l4t packages that are installed using apply_binaries.sh. However when flashing it with the minimal flavor (and same nvidia-l4t packages) it works to set the nvpmodel using the /etc/nvpmodel.conf file. Any clues on what this could be, or should i just compare the packages in the nvubuntu-focal-basic-aarch64-packages and nvubuntu-focal-minimal-aarch64-packages?
Hi hvbotten,
Are you using the devkit or custom board for Orin NX?
Could you share the /etc/nvpmodel.conf from your board as file here for further check?
I am using Seeed studios reComputer J4012
It was flashed using the driver package (BSP) with version 35.4.1, I never installed Jetpack at any point.
$ cat /etc/nv_tegra_release
# R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug 1 19:57:35 UTC 2023
Contents of /etc/nvpmodel.conf:
$ cat /etc/nvpmodel.conf
# Copyright (c) 2021-2023, NVIDIA CORPORATION. All rights reserved.
# NVIDIA CORPORATION and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA CORPORATION is strictly prohibited.
# FORMAT:
# < PARAM TYPE=PARAM_TYPE NAME=PARAM_NAME >
# ARG1_NAME ARG1_PATH_VAL
# ARG2_NAME ARG2_PATH_VAL
# This starts a section of PARAM definitions, in which each line
# has the syntax below:
# ARG_NAME ARG_PATH_VAL
# ARG_NAME is a macro name for argument value ARG_PATH_VAL.
# PARAM_TYPE can be FILE, or CLOCK.
# < POWER_MODEL ID=id_num NAME=mode_name >
# PARAM1_NAME ARG11_NAME ARG11_VAL
# PARAM1_NAME ARG12_NAME ARG12_VAL
# PARAM2_NAME ARG21_NAME ARG21_VAL
# This starts a section of POWER_MODEL configurations, followed by
# lines with parameter settings as the format below:
# PARAM_NAME ARG_NAME ARG_VAL
# PARAM_NAME and ARG_NAME are defined in PARAM definition sections.
# ARG_VAL is an integer for PARAM_TYPE of CLOCK, and -1 is taken
# as INT_MAX. ARG_VAL is a string for PARAM_TYPE of FILE.
# This file must contain at least one POWER_MODEL section.
# < PM_CONFIG DEFAULT=default_mode >
# This is a mandatory section to specify one of the defined power
# model as the default.
# PARAM DEFINITIONS #
< PARAM TYPE=FILE NAME=CPU_ONLINE >
CORE_0 /sys/devices/system/cpu/cpu0/online
CORE_1 /sys/devices/system/cpu/cpu1/online
CORE_2 /sys/devices/system/cpu/cpu2/online
CORE_3 /sys/devices/system/cpu/cpu3/online
CORE_4 /sys/devices/system/cpu/cpu4/online
CORE_5 /sys/devices/system/cpu/cpu5/online
CORE_6 /sys/devices/system/cpu/cpu6/online
CORE_7 /sys/devices/system/cpu/cpu7/online
< PARAM TYPE=FILE NAME=FBP_POWER_GATING >
FBP_PG_MASK /sys/devices/gpu.0/fbp_pg_mask
< PARAM TYPE=FILE NAME=TPC_POWER_GATING >
TPC_PG_MASK /sys/devices/gpu.0/tpc_pg_mask
< PARAM TYPE=FILE NAME=GPU_POWER_CONTROL_ENABLE >
GPU_PWR_CNTL_EN /sys/devices/gpu.0/power/control
< PARAM TYPE=FILE NAME=GPU_POWER_CONTROL_DISABLE >
GPU_PWR_CNTL_DIS /sys/devices/gpu.0/power/control
< PARAM TYPE=CLOCK NAME=CPU_A78_0 >
FREQ_TABLE /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
MAX_FREQ /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
MIN_FREQ /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
FREQ_TABLE_KNEXT /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
MAX_FREQ_KNEXT /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
MIN_FREQ_KNEXT /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
< PARAM TYPE=CLOCK NAME=CPU_A78_1 >
FREQ_TABLE /sys/devices/system/cpu/cpu4/cpufreq/scaling_available_frequencies
MAX_FREQ /sys/devices/system/cpu/cpu4/cpufreq/scaling_max_freq
MIN_FREQ /sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq
FREQ_TABLE_KNEXT /sys/devices/system/cpu/cpu4/cpufreq/scaling_available_frequencies
MAX_FREQ_KNEXT /sys/devices/system/cpu/cpu4/cpufreq/scaling_max_freq
MIN_FREQ_KNEXT /sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq
< PARAM TYPE=CLOCK NAME=GPU >
FREQ_TABLE /sys/devices/17000000.ga10b/devfreq/17000000.ga10b/available_frequencies
MAX_FREQ /sys/devices/17000000.ga10b/devfreq/17000000.ga10b/max_freq
MIN_FREQ /sys/devices/17000000.ga10b/devfreq/17000000.ga10b/min_freq
FREQ_TABLE_KNEXT /sys/devices/17000000.ga10b/devfreq_dev/available_frequencies
MAX_FREQ_KNEXT /sys/devices/17000000.ga10b/devfreq_dev/max_freq
MIN_FREQ_KNEXT /sys/devices/17000000.ga10b/devfreq_dev/min_freq
<PARAM TYPE=CLOCK NAME=EMC >
MAX_FREQ /sys/kernel/nvpmodel_emc_cap/emc_iso_cap
MAX_FREQ_KNEXT /sys/kernel/nvpmodel_emc_cap/emc_iso_cap
< PARAM TYPE=CLOCK NAME=DLA0_CORE >
MAX_FREQ /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_core
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_core
< PARAM TYPE=CLOCK NAME=DLA0_FALCON >
MAX_FREQ /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_falcon
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_falcon
< PARAM TYPE=CLOCK NAME=DLA1_CORE >
MAX_FREQ /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_core
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_core
< PARAM TYPE=CLOCK NAME=DLA1_FALCON >
MAX_FREQ /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_falcon
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_falcon
< PARAM TYPE=CLOCK NAME=PVA0_VPS >
MAX_FREQ /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_vps
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_vps
< PARAM TYPE=CLOCK NAME=PVA0_AXI >
MAX_FREQ /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_cpu_axi
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_cpu_axi
# POWER_MODEL DEFINITIONS #
# MAXN is the NONE power model to release all constraints
< POWER_MODEL ID=0 NAME=MAXN >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 1
CPU_ONLINE CORE_5 1
CPU_ONLINE CORE_6 1
CPU_ONLINE CORE_7 1
FBP_POWER_GATING FBP_PG_MASK 2
TPC_POWER_GATING TPC_PG_MASK 240
GPU_POWER_CONTROL_ENABLE GPU_PWR_CNTL_EN on
CPU_A78_0 MIN_FREQ 729600
CPU_A78_0 MAX_FREQ -1
CPU_A78_1 MIN_FREQ 729600
CPU_A78_1 MAX_FREQ -1
GPU MIN_FREQ 0
GPU MAX_FREQ -1
GPU_POWER_CONTROL_DISABLE GPU_PWR_CNTL_DIS auto
EMC MAX_FREQ 0
DLA0_CORE MAX_FREQ -1
DLA1_CORE MAX_FREQ -1
DLA0_FALCON MAX_FREQ -1
DLA1_FALCON MAX_FREQ -1
PVA0_VPS MAX_FREQ -1
PVA0_AXI MAX_FREQ -1
< POWER_MODEL ID=1 NAME=10W >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 0
CPU_ONLINE CORE_5 0
CPU_ONLINE CORE_6 0
CPU_ONLINE CORE_7 0
TPC_POWER_GATING TPC_PG_MASK 252
CPU_A78_0 MAX_FREQ 1190400
GPU MIN_FREQ 0
GPU MAX_FREQ 612000000
EMC MAX_FREQ 2133000000
DLA0_CORE MAX_FREQ 153600000
DLA1_CORE MAX_FREQ 115000000
DLA0_FALCON MAX_FREQ 115000000
DLA1_FALCON MAX_FREQ 115000000
PVA0_VPS MAX_FREQ 115000000
PVA0_AXI MAX_FREQ 115000000
< POWER_MODEL ID=2 NAME=15W >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 0
CPU_ONLINE CORE_5 0
CPU_ONLINE CORE_6 0
CPU_ONLINE CORE_7 0
CPU_A78_0 MAX_FREQ 1420800
GPU MIN_FREQ 0
EMC MAX_FREQ 0
DLA0_CORE MAX_FREQ 614400000
DLA0_FALCON MAX_FREQ 294400000
< POWER_MODEL ID=3 NAME=25W >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 1
CPU_ONLINE CORE_5 1
CPU_ONLINE CORE_6 1
CPU_ONLINE CORE_7 1
CPU_A78_0 MAX_FREQ 1497600
CPU_A78_1 MAX_FREQ 1497600
GPU MIN_FREQ 0
GPU MAX_FREQ 408000000
EMC MAX_FREQ 0
DLA1_CORE MAX_FREQ 614400000
DLA1_FALCON MAX_FREQ 294400000
PVA0_VPS MAX_FREQ 512000000
PVA0_AXI MAX_FREQ 358400000
# mandatory section to configure the default power mode
I worked my way through the package difference between basic and minimal, and found out that if I include the bc package everything works as expected. Now I can reboot and the power model gets set correctly from the config file. Not sure exactly how the bc package specifically interacts with nvpmodel though…
$ apt show bc
Package: bc
Version: 1.07.1-2build1
Priority: optional
Section: math
Origin: Ubuntu
Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
Original-Maintainer: Ryan Kavanagh <rak@debian.org>
Bugs: https://bugs.launchpad.net/ubuntu/+filebug
Installed-Size: 223 kB
Depends: libc6 (>= 2.17), libreadline8 (>= 6.0)
Homepage: http://ftp.gnu.org/gnu/bc/
Task: server, print-server, ubuntu-desktop-minimal, ubuntu-desktop, cloud-image, kubuntu-desktop, xubuntu-core, xubuntu-desktop, lubuntu-desktop, ubuntustudio-desktop-core, ubuntustudio-desktop, ubuntukylin-desktop, ubuntu-mate-core, ubuntu-mate-desktop, ubuntu-budgie-desktop
$ nvpmodel -q --verbose
NVPM VERB: Current mode: NV Power Mode: MAXN
0
system
Closed
December 19, 2023, 3:17am
7
