Using the command “nvpmodel -m 3” (for example) configures the operating mode for the platform. This mode value persists across power cycles. It does not appear that /etc/nvpmodel.conf or any of the /etc/nvpmodel/*.conf have an effect on what mode the unit powers up to, however. Where is this setting stored?
I’d like to create a system image that allows me to select a pre-defined mode without having to interactively run nvpmodel. Is this possible?
Hi tscott-jdes, see the PM_CONFIG DEFAULT line at the bottom of /etc/nvpmodel.conf:
< PM_CONFIG DEFAULT=N >
where N is the ID of the power mode.
Either I don’t understand how that parameter is supposed to work, or it simply has no effect.
Example:
- fresh power cycle
- sudo nvpmodel -q. Shows mode 2.
- sudo nvpmodel -m 3. Updates mode to 3.
- tail /etc/nvpmodel.conf. Shows default is 2.
- reboot
- sudo nvpmodel -q. Shows mode 3.
- tail /etc/nvpmodel.conf. Shows default is 2. If this defines mode 2, then why do I see mode 3 in the previous step?
The fact that the “nvpmodel -m 3” operation persists over power cycles tells me that the actual setting is stored somewhere else. Otherwise, /etc/nvpmodel.conf should have set the mode to 2, shouldn’t it?
Please delete /var/lib/nvpmodel/status file and reboot. It should then follow your setting in nvpmodel.conf
Do some of the configuration settings require a reboot in order to take effect (for boot reasons)? Or can we expect the settings to take effect after we execute the nvpmodel command? and then launch jetson_clocks?
Hi kurt_ottaway,
Please open a new topic for your issue.
