It’s ok sudo nvpmodel -m 0.
but configure PM_CONFIG DEFAULT=0 in /etc/nvpmodel.conf, and reboot, it doesn’t wok, show only 4 cpus are working.
mandatory section to configure the default power mode
< PM_CONFIG DEFAULT=0 >
thanks.
hello os.kernel,
were you able to change the power mode via command-line, i.e. $ sudo /usr/sbin/nvpmodel -m 0
sudo /usr/sbin/nvpmodel -m 0 is ok.
We need customize the rootfs. so the config file is what we want.
But modify the /etc/nvpmodel.conf doesn’t work.
how to achieve it?
thanks.
hello os.kernel,
please narrow down the issue,
could you please try configure with different modes in nvpmodel.conf.
thanks
hello os.kernel,
it looks like a bug, could you please enable verbose log and sharing all logs for reference,
$ nvpmodel --help
--verbose:
Enable verbose log.
-p, --parse:
Parse the config file only. Recommended to enable verbose log.
for example, $ nvpmodel --verbose -p -f nvpmodel.conf.
x@localhost:~$ sudo nvpmodel --verbose -p -f nvpmodel.conf
NVPM VERB: Config file: nvpmodel.conf
NVPM ERROR: null input file!
NVPM ERROR: Failed to parse nvpmodel.conf
NVPM ERROR: Invalid power mode set in /var/lib/nvpmodel/status, using default settings.
keda@localhost:~$ sudo nvpmodel --verbose -p -f /etc/nvpmodel.conf
NVPM VERB: Config file: /etc/nvpmodel.conf
NVPM VERB: parsing done for /etc/nvpmodel.conf
succeed to parse file /etc/nvpmodel.conf.
NVPM VERB: PM_CONFIG: DEFAULT=MODE_30W_2CORE(6)
NVPM VERB: PARAM TYPE=FILE NAME=CPU_ONLINE
NVPM VERB: CORE_0 /sys/devices/system/cpu/cpu0/online
NVPM VERB: CORE_1 /sys/devices/system/cpu/cpu1/online
NVPM VERB: CORE_2 /sys/devices/system/cpu/cpu2/online
NVPM VERB: CORE_3 /sys/devices/system/cpu/cpu3/online
NVPM VERB: CORE_4 /sys/devices/system/cpu/cpu4/online
NVPM VERB: CORE_5 /sys/devices/system/cpu/cpu5/online
NVPM VERB: CORE_6 /sys/devices/system/cpu/cpu6/online
NVPM VERB: CORE_7 /sys/devices/system/cpu/cpu7/online
NVPM VERB: PARAM TYPE=FILE NAME=TPC_POWER_GATING
NVPM VERB: TPC_PG_MASK /sys/devices/gpu.0/tpc_pg_mask
NVPM VERB: PARAM TYPE=FILE NAME=GPU_POWER_CONTROL_ENABLE
NVPM VERB: GPU_PWR_CNTL_EN /sys/devices/gpu.0/power/control
NVPM VERB: PARAM TYPE=FILE NAME=GPU_POWER_CONTROL_DISABLE
NVPM VERB: GPU_PWR_CNTL_DIS /sys/devices/gpu.0/power/control
NVPM VERB: PARAM TYPE=CLOCK NAME=CPU_DENVER_0
NVPM VERB: FREQ_TABLE /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
NVPM VERB: MAX_FREQ /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
NVPM VERB: MIN_FREQ /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
NVPM VERB: PARAM TYPE=CLOCK NAME=CPU_DENVER_1
NVPM VERB: FREQ_TABLE /sys/devices/system/cpu/cpu2/cpufreq/scaling_available_frequencies
NVPM VERB: MAX_FREQ /sys/devices/system/cpu/cpu2/cpufreq/scaling_max_freq
NVPM VERB: MIN_FREQ /sys/devices/system/cpu/cpu2/cpufreq/scaling_min_freq
NVPM VERB: PARAM TYPE=CLOCK NAME=CPU_DENVER_2
NVPM VERB: FREQ_TABLE /sys/devices/system/cpu/cpu4/cpufreq/scaling_available_frequencies
NVPM VERB: MAX_FREQ /sys/devices/system/cpu/cpu4/cpufreq/scaling_max_freq
NVPM VERB: MIN_FREQ /sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq
NVPM VERB: PARAM TYPE=CLOCK NAME=CPU_DENVER_3
NVPM VERB: FREQ_TABLE /sys/devices/system/cpu/cpu6/cpufreq/scaling_available_frequencies
NVPM VERB: MAX_FREQ /sys/devices/system/cpu/cpu6/cpufreq/scaling_max_freq
NVPM VERB: MIN_FREQ /sys/devices/system/cpu/cpu6/cpufreq/scaling_min_freq
NVPM VERB: PARAM TYPE=CLOCK NAME=GPU
NVPM VERB: FREQ_TABLE /sys/devices/17000000.gv11b/devfreq/17000000.gv11b/available_frequencies
NVPM VERB: MAX_FREQ /sys/devices/17000000.gv11b/devfreq/17000000.gv11b/max_freq
NVPM VERB: MIN_FREQ /sys/devices/17000000.gv11b/devfreq/17000000.gv11b/min_freq
NVPM VERB: PARAM TYPE=CLOCK NAME=EMC
NVPM VERB: MAX_FREQ /sys/kernel/nvpmodel_emc_cap/emc_iso_cap
NVPM VERB: PARAM TYPE=CLOCK NAME=DLA_CORE
NVPM VERB: MAX_FREQ /sys/kernel/nvpmodel_emc_cap/nafll_dla
NVPM VERB: PARAM TYPE=CLOCK NAME=DLA_FALCON
NVPM VERB: MAX_FREQ /sys/kernel/nvpmodel_emc_cap/nafll_dla_falcon
NVPM VERB: PARAM TYPE=CLOCK NAME=PVA_VPS
NVPM VERB: MAX_FREQ /sys/kernel/nvpmodel_emc_cap/nafll_pva_vps
NVPM VERB: PARAM TYPE=CLOCK NAME=PVA_CORE
NVPM VERB: MAX_FREQ /sys/kernel/nvpmodel_emc_cap/nafll_pva_core
NVPM VERB: PARAM TYPE=CLOCK NAME=CVNAS
NVPM VERB: MAX_FREQ /sys/kernel/nvpmodel_emc_cap/nafll_cvnas
NVPM VERB:
NVPM VERB: POWER_MODEL: ID=0 NAME=MAXN
NVPM VERB: CPU_ONLINE CORE_0 1
NVPM VERB: CPU_ONLINE CORE_1 1
NVPM VERB: CPU_ONLINE CORE_2 1
NVPM VERB: CPU_ONLINE CORE_3 1
NVPM VERB: CPU_ONLINE CORE_4 1
NVPM VERB: CPU_ONLINE CORE_5 1
NVPM VERB: CPU_ONLINE CORE_6 1
NVPM VERB: CPU_ONLINE CORE_7 1
NVPM VERB: TPC_POWER_GATING TPC_PG_MASK 0
NVPM VERB: GPU_POWER_CONTROL_ENABLE GPU_PWR_CNTL_EN on
NVPM VERB: CPU_DENVER_0 MIN_FREQ 1200000
NVPM VERB: CPU_DENVER_0 MAX_FREQ 2147483647
NVPM VERB: CPU_DENVER_1 MIN_FREQ 1200000
NVPM VERB: CPU_DENVER_1 MAX_FREQ 2147483647
NVPM VERB: CPU_DENVER_2 MIN_FREQ 1200000
NVPM VERB: CPU_DENVER_2 MAX_FREQ 2147483647
NVPM VERB: CPU_DENVER_3 MIN_FREQ 1200000
NVPM VERB: CPU_DENVER_3 MAX_FREQ 2147483647
NVPM VERB: GPU MIN_FREQ 318750000
NVPM VERB: GPU MAX_FREQ 2147483647
NVPM VERB: GPU_POWER_CONTROL_DISABLE GPU_PWR_CNTL_DIS auto
NVPM VERB: EMC MAX_FREQ 0
NVPM VERB: DLA_CORE MAX_FREQ 2147483647
NVPM VERB: DLA_FALCON MAX_FREQ 2147483647
NVPM VERB: PVA_VPS MAX_FREQ 2147483647
NVPM VERB: PVA_CORE MAX_FREQ 2147483647
NVPM VERB: CVNAS MAX_FREQ 2147483647
NVPM VERB:
NVPM VERB: POWER_MODEL: ID=1 NAME=MODE_10W
NVPM VERB: CPU_ONLINE CORE_2 0
NVPM VERB: CPU_ONLINE CORE_3 0
NVPM VERB: CPU_ONLINE CORE_4 0
NVPM VERB: CPU_ONLINE CORE_5 0
NVPM VERB: CPU_ONLINE CORE_6 0
NVPM VERB: CPU_ONLINE CORE_7 0
NVPM VERB: TPC_POWER_GATING TPC_PG_MASK 5
NVPM VERB: CPU_DENVER_0 MAX_FREQ 1200000
NVPM VERB: GPU MAX_FREQ 520000000
NVPM VERB: EMC MAX_FREQ 1065600000
NVPM VERB: DLA_CORE MAX_FREQ 550000000
NVPM VERB: DLA_FALCON MAX_FREQ 330000000
NVPM VERB: PVA_VPS MAX_FREQ 115200000
NVPM VERB: PVA_CORE MAX_FREQ 115200000
NVPM VERB: CVNAS MAX_FREQ 601600000
NVPM VERB:
NVPM VERB: POWER_MODEL: ID=2 NAME=MODE_15W
NVPM VERB: CPU_DENVER_1 MAX_FREQ 1200000
NVPM VERB: GPU MAX_FREQ 670000000
NVPM VERB: EMC MAX_FREQ 1331200000
NVPM VERB: DLA_CORE MAX_FREQ 750000000
NVPM VERB: DLA_FALCON MAX_FREQ 450000000
NVPM VERB: PVA_VPS MAX_FREQ 550000000
NVPM VERB: PVA_CORE MAX_FREQ 385000000
NVPM VERB: CVNAS MAX_FREQ 716800000
NVPM VERB:
NVPM VERB: POWER_MODEL: ID=3 NAME=MODE_30W_ALL
NVPM VERB: CPU_DENVER_2 MAX_FREQ 1200000
NVPM VERB: CPU_DENVER_3 MAX_FREQ 1200000
NVPM VERB: GPU MAX_FREQ 900000000
NVPM VERB: EMC MAX_FREQ 1600000000
NVPM VERB: DLA_CORE MAX_FREQ 1050000000
NVPM VERB: DLA_FALCON MAX_FREQ 630000000
NVPM VERB: PVA_VPS MAX_FREQ 760000000
NVPM VERB: PVA_CORE MAX_FREQ 532000000
NVPM VERB: CVNAS MAX_FREQ 1011200000
NVPM VERB:
NVPM VERB: POWER_MODEL: ID=4 NAME=MODE_30W_6CORE
NVPM VERB: CPU_DENVER_0 MAX_FREQ 1450000
NVPM VERB: CPU_DENVER_1 MAX_FREQ 1450000
NVPM VERB: CPU_DENVER_2 MAX_FREQ 1450000
NVPM VERB:
NVPM VERB: POWER_MODEL: ID=5 NAME=MODE_30W_4CORE
NVPM VERB: CPU_DENVER_0 MAX_FREQ 1780000
NVPM VERB: CPU_DENVER_1 MAX_FREQ 1780000
NVPM VERB:
NVPM VERB: POWER_MODEL: ID=6 NAME=MODE_30W_2CORE
NVPM VERB: CPU_DENVER_0 MAX_FREQ 2100000
NVPM VERB:
NVPM VERB: POWER_MODEL: ID=7 NAME=MODE_15W_DESKTOP
NVPM VERB: CPU_DENVER_0 MAX_FREQ 2188800
NVPM VERB: CPU_DENVER_1 MAX_FREQ 2188800
NVPM VERB: DLA_CORE MAX_FREQ 115200000
NVPM VERB: DLA_FALCON MAX_FREQ 115200000
NVPM VERB: CVNAS MAX_FREQ 115200000
NVPM VERB:
x@localhost:~$
x@localhost:~$ sudo nvpmodel -q
NV Fan Mode:quiet
NV Power Mode: MODE_15W_DESKTOP
7
x@localhost:~$ cat /etc/nvpmodel.conf | grep PM_CONFIG
< PM_CONFIG DEFAULT=6 >
hello os.kernel,
this is expected behavior, and it’s done on purpose to have persistent power mode settings over reboot.
on the first boot “PM_CONFIG DEFAULT” setting will be used from the nvpmodel.conf file. and this mode will be saved in a status file, /var/lib/nvpmodel/status.
thus, after the first boot you can only change the power mode by using the command-line, $ sudo nvpmodel -m <x>.
hence, you may delete the status file to accomplish your use-case.
please have a try to modify the default setting, then delete /var/lib/nvpmodel/status before reboot the system.
thanks
delete /var/lib/nvpmodel/status is ok.
although it is a little confuse.
thanks!
