I have the same problem, with same board, as the post here: NVPM WARN: power mode is not set! And cannot set it using config file
I am not sure what the user meant by the “bc” package.
The /etc/nvpmodel.conf gives me:
# Copyright (c) 2021-2023, NVIDIA CORPORATION. All rights reserved.
# NVIDIA CORPORATION and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA CORPORATION is strictly prohibited.
# FORMAT:
# < PARAM TYPE=PARAM_TYPE NAME=PARAM_NAME >
# ARG1_NAME ARG1_PATH_VAL
# ARG2_NAME ARG2_PATH_VAL
# This starts a section of PARAM definitions, in which each line
# has the syntax below:
# ARG_NAME ARG_PATH_VAL
# ARG_NAME is a macro name for argument value ARG_PATH_VAL.
# PARAM_TYPE can be FILE, or CLOCK.
# < POWER_MODEL ID=id_num NAME=mode_name >
# PARAM1_NAME ARG11_NAME ARG11_VAL
# PARAM1_NAME ARG12_NAME ARG12_VAL
# PARAM2_NAME ARG21_NAME ARG21_VAL
# This starts a section of POWER_MODEL configurations, followed by
# lines with parameter settings as the format below:
# PARAM_NAME ARG_NAME ARG_VAL
# PARAM_NAME and ARG_NAME are defined in PARAM definition sections.
# ARG_VAL is an integer for PARAM_TYPE of CLOCK, and -1 is taken
# as INT_MAX. ARG_VAL is a string for PARAM_TYPE of FILE.
# This file must contain at least one POWER_MODEL section.
# < PM_CONFIG DEFAULT=default_mode >
# This is a mandatory section to specify one of the defined power
# model as the default.
# PARAM DEFINITIONS #
< PARAM TYPE=FILE NAME=CPU_ONLINE >
CORE_0 /sys/devices/system/cpu/cpu0/online
CORE_1 /sys/devices/system/cpu/cpu1/online
CORE_2 /sys/devices/system/cpu/cpu2/online
CORE_3 /sys/devices/system/cpu/cpu3/online
CORE_4 /sys/devices/system/cpu/cpu4/online
CORE_5 /sys/devices/system/cpu/cpu5/online
CORE_6 /sys/devices/system/cpu/cpu6/online
CORE_7 /sys/devices/system/cpu/cpu7/online
< PARAM TYPE=FILE NAME=FBP_POWER_GATING >
FBP_PG_MASK /sys/devices/gpu.0/fbp_pg_mask
< PARAM TYPE=FILE NAME=TPC_POWER_GATING >
TPC_PG_MASK /sys/devices/gpu.0/tpc_pg_mask
< PARAM TYPE=FILE NAME=GPU_POWER_CONTROL_ENABLE >
GPU_PWR_CNTL_EN /sys/devices/gpu.0/power/control
< PARAM TYPE=FILE NAME=GPU_POWER_CONTROL_DISABLE >
GPU_PWR_CNTL_DIS /sys/devices/gpu.0/power/control
< PARAM TYPE=CLOCK NAME=CPU_A78_0 >
FREQ_TABLE /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
MAX_FREQ /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
MIN_FREQ /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
FREQ_TABLE_KNEXT /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
MAX_FREQ_KNEXT /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
MIN_FREQ_KNEXT /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
< PARAM TYPE=CLOCK NAME=CPU_A78_1 >
FREQ_TABLE /sys/devices/system/cpu/cpu4/cpufreq/scaling_available_frequencies
MAX_FREQ /sys/devices/system/cpu/cpu4/cpufreq/scaling_max_freq
MIN_FREQ /sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq
FREQ_TABLE_KNEXT /sys/devices/system/cpu/cpu4/cpufreq/scaling_available_frequencies
MAX_FREQ_KNEXT /sys/devices/system/cpu/cpu4/cpufreq/scaling_max_freq
MIN_FREQ_KNEXT /sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq
< PARAM TYPE=CLOCK NAME=GPU >
FREQ_TABLE /sys/devices/17000000.ga10b/devfreq/17000000.ga10b/available_frequencies
MAX_FREQ /sys/devices/17000000.ga10b/devfreq/17000000.ga10b/max_freq
MIN_FREQ /sys/devices/17000000.ga10b/devfreq/17000000.ga10b/min_freq
FREQ_TABLE_KNEXT /sys/devices/17000000.ga10b/devfreq_dev/available_frequencies
MAX_FREQ_KNEXT /sys/devices/17000000.ga10b/devfreq_dev/max_freq
MIN_FREQ_KNEXT /sys/devices/17000000.ga10b/devfreq_dev/min_freq
<PARAM TYPE=CLOCK NAME=EMC >
MAX_FREQ /sys/kernel/nvpmodel_emc_cap/emc_iso_cap
MAX_FREQ_KNEXT /sys/kernel/nvpmodel_emc_cap/emc_iso_cap
< PARAM TYPE=CLOCK NAME=DLA0_CORE >
MAX_FREQ /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_core
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_core
< PARAM TYPE=CLOCK NAME=DLA0_FALCON >
MAX_FREQ /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_falcon
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_falcon
< PARAM TYPE=CLOCK NAME=DLA1_CORE >
MAX_FREQ /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_core
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_core
< PARAM TYPE=CLOCK NAME=DLA1_FALCON >
MAX_FREQ /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_falcon
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_falcon
< PARAM TYPE=CLOCK NAME=PVA0_VPS >
MAX_FREQ /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_vps
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_vps
< PARAM TYPE=CLOCK NAME=PVA0_AXI >
MAX_FREQ /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_cpu_axi
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_cpu_axi
# POWER_MODEL DEFINITIONS #
# MAXN is the NONE power model to release all constraints
< POWER_MODEL ID=0 NAME=MAXN >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 1
CPU_ONLINE CORE_5 1
CPU_ONLINE CORE_6 1
CPU_ONLINE CORE_7 1
FBP_POWER_GATING FBP_PG_MASK 2
TPC_POWER_GATING TPC_PG_MASK 240
GPU_POWER_CONTROL_ENABLE GPU_PWR_CNTL_EN on
CPU_A78_0 MIN_FREQ 729600
CPU_A78_0 MAX_FREQ -1
CPU_A78_1 MIN_FREQ 729600
CPU_A78_1 MAX_FREQ -1
GPU MIN_FREQ 0
GPU MAX_FREQ -1
GPU_POWER_CONTROL_DISABLE GPU_PWR_CNTL_DIS auto
EMC MAX_FREQ 0
DLA0_CORE MAX_FREQ -1
DLA1_CORE MAX_FREQ -1
DLA0_FALCON MAX_FREQ -1
DLA1_FALCON MAX_FREQ -1
PVA0_VPS MAX_FREQ -1
PVA0_AXI MAX_FREQ -1
< POWER_MODEL ID=1 NAME=10W >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 0
CPU_ONLINE CORE_5 0
CPU_ONLINE CORE_6 0
CPU_ONLINE CORE_7 0
TPC_POWER_GATING TPC_PG_MASK 252
CPU_A78_0 MAX_FREQ 1190400
GPU MIN_FREQ 0
GPU MAX_FREQ 612000000
EMC MAX_FREQ 2133000000
DLA0_CORE MAX_FREQ 153600000
DLA1_CORE MAX_FREQ 115000000
DLA0_FALCON MAX_FREQ 115000000
DLA1_FALCON MAX_FREQ 115000000
PVA0_VPS MAX_FREQ 115000000
PVA0_AXI MAX_FREQ 115000000
< POWER_MODEL ID=2 NAME=15W >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 0
CPU_ONLINE CORE_5 0
CPU_ONLINE CORE_6 0
CPU_ONLINE CORE_7 0
CPU_A78_0 MAX_FREQ 1420800
GPU MIN_FREQ 0
EMC MAX_FREQ 0
DLA0_CORE MAX_FREQ 614400000
DLA0_FALCON MAX_FREQ 294400000
< POWER_MODEL ID=3 NAME=25W >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 1
CPU_ONLINE CORE_5 1
CPU_ONLINE CORE_6 1
CPU_ONLINE CORE_7 1
CPU_A78_0 MAX_FREQ 1497600
CPU_A78_1 MAX_FREQ 1497600
GPU MIN_FREQ 0
GPU MAX_FREQ 408000000
EMC MAX_FREQ 0
DLA1_CORE MAX_FREQ 614400000
DLA1_FALCON MAX_FREQ 294400000
PVA0_VPS MAX_FREQ 512000000
PVA0_AXI MAX_FREQ 358400000
# mandatory section to configure the default power mode
< PM_CONFIG DEFAULT=2 >
As well, following Jetson Orin NX Series and Jetson AGX Orin Series — Jetson Linux<br/>Developer Guide 34.1 documentation , is there a way to change the nvpmodel profile without power cycling the board ? As in:
ubuntu@jetson:~$ sudo nvpmodel -m 2
NVPM ERROR: Error writing 240 to /sys/devices/gpu.0/tpc_pg_mask: 19
NVPM WARN: Reboot required for changing to this power mode: 2
NVPM WARN: DO YOU WANT TO REBOOT NOW? enter YES/yes to confirm:
Thank you
