Orin Nano 8GB 7W profile?
How does one enable the 7W power profile for the Orin Nano 8GB? or is this even possible. From the data sheet there is mention of a 7W profile however nvpmodel.conf only has 10/15/20/MaxN.
I have flashed 35.5 using the quick start guide and using profile jetson-orin-nano-devkit. I assume the power profile should be available via the nvpmodel tool?
https://docs.nvidia.com/jetson/archives/r35.5.0/DeveloperGuide/IN/QuickStart.html#
Please check the power modes for each platform:
Jetson Orin Nano Series, Jetson Orin NX Series and Jetson AGX Orin Series — NVIDIA Jetson Linux Developer Guide 1 documentation
We support 7W mode on Orin Nano 8GB. You can run $ sudo nvpmodel -m 1 and reboot the system to enter the mode.
Thank you, mode 1 is 10W (i have this and confirmed).
There is no 7W profile is in /etc/nvpmodel.conf
Possible bug in LT4 35.5?
Please run the command to ensure the nvpmodel.conf is correct:
$ ll /etc/nvpmodel.conf
lrwxrwxrwx 1 root root 38 Nov 21  2023 /etc/nvpmodel.conf -> /etc/nvpmodel/nvpmodel_p3767_0003.conf
$ cat /etc/nvpmodel/nvpmodel_p3767_0003.conf
# Copyright (c) 2021-2023, NVIDIA CORPORATION.  All rights reserved.
# NVIDIA CORPORATION and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto.  Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA CORPORATION is strictly prohibited.
# FORMAT:
# < PARAM TYPE=PARAM_TYPE NAME=PARAM_NAME >
# ARG1_NAME ARG1_PATH_VAL
# ARG2_NAME ARG2_PATH_VAL
# This starts a section of PARAM definitions, in which each line
# has the syntax below:
# ARG_NAME ARG_PATH_VAL
# ARG_NAME is a macro name for argument value ARG_PATH_VAL.
# PARAM_TYPE can be FILE, or CLOCK.
# < POWER_MODEL ID=id_num NAME=mode_name >
# PARAM1_NAME ARG11_NAME ARG11_VAL
# PARAM1_NAME ARG12_NAME ARG12_VAL
# PARAM2_NAME ARG21_NAME ARG21_VAL
# This starts a section of POWER_MODEL configurations, followed by
# lines with parameter settings as the format below:
# PARAM_NAME ARG_NAME ARG_VAL
# PARAM_NAME and ARG_NAME are defined in PARAM definition sections.
# ARG_VAL is an integer for PARAM_TYPE of CLOCK, and -1 is taken
# as INT_MAX. ARG_VAL is a string for PARAM_TYPE of FILE.
# This file must contain at least one POWER_MODEL section.
# < PM_CONFIG DEFAULT=default_mode >
# This is a mandatory section to specify one of the defined power
# model as the default.
# PARAM DEFINITIONS       #
< PARAM TYPE=FILE NAME=CPU_ONLINE >
CORE_0 /sys/devices/system/cpu/cpu0/online
CORE_1 /sys/devices/system/cpu/cpu1/online
CORE_2 /sys/devices/system/cpu/cpu2/online
CORE_3 /sys/devices/system/cpu/cpu3/online
CORE_4 /sys/devices/system/cpu/cpu4/online
CORE_5 /sys/devices/system/cpu/cpu5/online
< PARAM TYPE=FILE NAME=FBP_POWER_GATING >
FBP_PG_MASK /sys/devices/gpu.0/fbp_pg_mask
FBP_PG_MASK_KNEXT /sys/devices/platform/gpu.0/fbp_pg_mask
< PARAM TYPE=FILE NAME=TPC_POWER_GATING >
TPC_PG_MASK /sys/devices/gpu.0/tpc_pg_mask
TPC_PG_MASK_KNEXT /sys/devices/platform/gpu.0/tpc_pg_mask
< PARAM TYPE=FILE NAME=GPU_POWER_CONTROL_ENABLE >
GPU_PWR_CNTL_EN /sys/devices/gpu.0/power/control
GPU_PWR_CNTL_EN_KNEXT /sys/devices/platform/gpu.0/power/control
< PARAM TYPE=FILE NAME=GPU_POWER_CONTROL_DISABLE >
GPU_PWR_CNTL_DIS /sys/devices/gpu.0/power/control
GPU_PWR_CNTL_DIS_KNEXT /sys/devices/platform/gpu.0/power/control
< PARAM TYPE=CLOCK NAME=CPU_A78_0 >
FREQ_TABLE /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
MAX_FREQ /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
MIN_FREQ /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
FREQ_TABLE_KNEXT /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequenc
ies
MAX_FREQ_KNEXT /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
MIN_FREQ_KNEXT /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
< PARAM TYPE=CLOCK NAME=CPU_A78_1 >
FREQ_TABLE /sys/devices/system/cpu/cpu4/cpufreq/scaling_available_frequencies
MAX_FREQ /sys/devices/system/cpu/cpu4/cpufreq/scaling_max_freq
MIN_FREQ /sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq
FREQ_TABLE_KNEXT /sys/devices/system/cpu/cpu4/cpufreq/scaling_available_frequenc
ies
MAX_FREQ_KNEXT /sys/devices/system/cpu/cpu4/cpufreq/scaling_max_freq
MIN_FREQ_KNEXT /sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq
< PARAM TYPE=CLOCK NAME=GPU >
FREQ_TABLE /sys/devices/17000000.ga10b/devfreq/17000000.ga10b/available_frequenc
ies
MAX_FREQ /sys/devices/17000000.ga10b/devfreq/17000000.ga10b/max_freq
MIN_FREQ /sys/devices/17000000.ga10b/devfreq/17000000.ga10b/min_freq
FREQ_TABLE_KNEXT /sys/devices/platform/17000000.gpu/devfreq_dev/available_freque
ncies
MAX_FREQ_KNEXT /sys/devices/platform/17000000.gpu/devfreq_dev/max_freq
MIN_FREQ_KNEXT /sys/devices/platform/17000000.gpu/devfreq_dev/min_freq
<PARAM TYPE=CLOCK NAME=EMC >
MAX_FREQ /sys/kernel/nvpmodel_emc_cap/emc_iso_cap
MAX_FREQ_KNEXT /sys/kernel/nvpmodel_clk_cap/emc
# POWER_MODEL DEFINITIONS #
< POWER_MODEL ID=0 NAME=15W >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 1
CPU_ONLINE CORE_5 1
FBP_POWER_GATING FBP_PG_MASK 2
TPC_POWER_GATING TPC_PG_MASK 240
GPU_POWER_CONTROL_ENABLE GPU_PWR_CNTL_EN on
CPU_A78_0 MIN_FREQ 729600
CPU_A78_0 MAX_FREQ -1
CPU_A78_1 MIN_FREQ 729600
CPU_A78_1 MAX_FREQ -1
GPU MIN_FREQ 0
GPU MAX_FREQ -1
GPU_POWER_CONTROL_DISABLE GPU_PWR_CNTL_DIS auto
EMC MAX_FREQ -1
< POWER_MODEL ID=1 NAME=7W >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 0
CPU_ONLINE CORE_5 0
TPC_POWER_GATING TPC_PG_MASK 252
CPU_A78_0 MAX_FREQ 960000
GPU MIN_FREQ 0
GPU MAX_FREQ 408000000
EMC MAX_FREQ 2133000000
# mandatory section to configure the default power mode
< PM_CONFIG DEFAULT=0 >
See below:
Is there any issue with fixing the symlink to point to the correct file?
lrwxrwxrwx 1 root root 38 Nov 21 21:10 /etc/nvpmodel.conf -> /etc/nvpmodel/nvpmodel_p3767_0000.conf
$ cat /etc/nvpmodel/nvpmodel_p3767_0000.conf
# Copyright (c) 2021-2022, NVIDIA CORPORATION.  All rights reserved.
# FORMAT:
CORE_6 /sys/devices/system/cpu/cpu6/online
CORE_7 /sys/devices/system/cpu/cpu7/online
FREQ_TABLE_KNEXT /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
FREQ_TABLE_KNEXT /sys/devices/system/cpu/cpu4/cpufreq/scaling_available_frequencies
FREQ_TABLE /sys/devices/17000000.ga10b/devfreq/17000000.ga10b/available_frequencies
FREQ_TABLE_KNEXT /sys/devices/17000000.ga10b/devfreq_dev/available_frequencies
MAX_FREQ_KNEXT /sys/devices/17000000.ga10b/devfreq_dev/max_freq
MIN_FREQ_KNEXT /sys/devices/17000000.ga10b/devfreq_dev/min_freq
MAX_FREQ_KNEXT /sys/kernel/nvpmodel_emc_cap/emc_iso_cap
< PARAM TYPE=CLOCK NAME=DLA0_CORE >
MAX_FREQ /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_core
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_core
< PARAM TYPE=CLOCK NAME=DLA0_FALCON >
MAX_FREQ /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_falcon
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/15880000.nvdla0/acm/clk_cap/dla0_falcon
< PARAM TYPE=CLOCK NAME=DLA1_CORE >
MAX_FREQ /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_core
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_core
< PARAM TYPE=CLOCK NAME=DLA1_FALCON >
MAX_FREQ /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_falcon
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/158c0000.nvdla1/acm/clk_cap/dla1_falcon
< PARAM TYPE=CLOCK NAME=PVA0_VPS >
MAX_FREQ /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_vps
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_vps
< PARAM TYPE=CLOCK NAME=PVA0_AXI >
MAX_FREQ /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_cpu_axi
MAX_FREQ_KNEXT /sys/devices/platform/13e40000.host1x/16000000.pva0/acm/clk_cap/pva0_cpu_axi
# MAXN is the NONE power model to release all constraints
< POWER_MODEL ID=0 NAME=MAXN >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 1
CPU_ONLINE CORE_5 1
CPU_ONLINE CORE_6 1
CPU_ONLINE CORE_7 1
GPU MIN_FREQ 0
GPU MAX_FREQ -1
EMC MAX_FREQ 0
DLA0_CORE MAX_FREQ -1
DLA1_CORE MAX_FREQ -1
DLA0_FALCON MAX_FREQ -1
DLA1_FALCON MAX_FREQ -1
PVA0_VPS MAX_FREQ -1
PVA0_AXI MAX_FREQ -1
< POWER_MODEL ID=1 NAME=10W >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 0
CPU_ONLINE CORE_5 0
CPU_ONLINE CORE_6 0
CPU_ONLINE CORE_7 0
CPU_A78_0 MAX_FREQ 1190400
GPU MIN_FREQ 0
GPU MAX_FREQ 612000000
DLA0_CORE MAX_FREQ 153600000
DLA1_CORE MAX_FREQ 115000000
DLA0_FALCON MAX_FREQ 115000000
DLA1_FALCON MAX_FREQ 115000000
PVA0_VPS MAX_FREQ 115000000
PVA0_AXI MAX_FREQ 115000000
< POWER_MODEL ID=2 NAME=15W >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 0
CPU_ONLINE CORE_5 0
CPU_ONLINE CORE_6 0
CPU_ONLINE CORE_7 0
CPU_A78_0 MAX_FREQ 1651200
GPU MIN_FREQ 0
EMC MAX_FREQ 0
DLA0_CORE MAX_FREQ 614400000
DLA1_CORE MAX_FREQ 614400000
DLA0_FALCON MAX_FREQ 294400000
DLA1_FALCON MAX_FREQ 294400000
< POWER_MODEL ID=3 NAME=25W >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 1
CPU_ONLINE CORE_5 1
CPU_ONLINE CORE_6 1
CPU_ONLINE CORE_7 1
CPU_A78_0 MAX_FREQ 1497600
CPU_A78_1 MAX_FREQ 1497600
GPU MIN_FREQ 0
EMC MAX_FREQ 0
PVA0_VPS MAX_FREQ 512000000
PVA0_AXI MAX_FREQ 358400000
< PM_CONFIG DEFAULT=2 >
You may be using Orin NX instead of Orin Nano. Please run the command to confirm what the module is
$ sudo i2cdump -y -f 0 0x50
Hi request below
What are you looking for in this?
No size specified (using byte-data access)
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f    0123456789abcdef
00: 02 00 fe 00 00 00 00 00 00 00 00 ff 00 00 00 00    ?.?.............
10: 00 01 00 01 36 39 39 2d 31 33 37 36 37 2d 30 30    .?.?699-13767-00
20: 30 35 2d 33 30 30 20 4b 2e 32 00 00 00 00 00 00    05-300 K.2......
30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
40: b0 48 00 00 d7 0d ec 2d b0 48 31 34 32 31 36 32    ?H..???-?H142162
50: 33 30 32 39 31 36 33 00 00 00 00 00 00 00 00 00    3029163.........
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
90: 00 00 00 00 00 00 4e 56 43 42 00 ff 4d 31 00 00    ......NVCB..M1..
a0: 00 00 00 00 00 00 00 00 00 00 00 00 d7 0d ec 2d    ............???-
b0: b0 48 01 00 00 00 00 00 00 00 00 00 00 00 00 00    ?H?.............
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 cf    ...............?
It shows 3767-0005 which is Orin Nano 8GB. It is strange that nvpmodel does not link to correct config. Please re-flash the system and see if the setup is correct in a clean system.
I have flashed multiple SoMs and across multiple hosts. I can confirm the the issue is present in L4T35.3.1 as well as L4T35.5.
For L4T35.5 I followed the instructions as per my initial post.
We set up Orin Nano 8GB developer kit with the Jetpack releases:
6.0GA(r36.3)
5.1.3(r35.5.0)
The nvpmodel config is correctly loaded on the two versions. Please try to re-flash the system with the initrd command:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1
-c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml"
–showlogs --network usb0 jetson-orin-nano-devkit internal
And see if the issue is still present.
Followed instructions for 35.5 Quick start and still have the same result
Noting you have possible error in -showlogs of your command that caused an error.
My command history
export L4T_RELEASE_PACKAGE=Jetson_Linux_R35.5.0_aarch64.tbz2
export SAMPLE_FS_PACKAGE=Tegra_Linux_Sample-Root-Filesystem_R35.5.0_aarch64.tbz2
export BOARD=jetson-orin-nano-devkit
cd ~/Projects/L4T_355/
tar xf ${L4T_RELEASE_PACKAGE}
sudo tar xpf ${SAMPLE_FS_PACKAGE} -C Linux_for_Tegra/rootfs/
cd Linux_for_Tegra/
sudo ./apply_binaries.sh
sudo ./tools/l4t_flash_prerequisites.sh
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" –showlogs --network usb0 jetson-orin-nano-devkit internal
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1   -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml"   --showlogs --network usb0 jetson-orin-nano-devkit internal
lrwxrwxrwx 1 root root 38 Mar 28  2023 /etc/nvpmodel.conf -> /etc/nvpmodel/nvpmodel_p3767_0001.conf
I downloaded my sources from
So i just flashed same build from above to my SoM that came on a Dev Kit (has on board SD card). The file was linked correctly. The issue seems to be with Production Orin Nano 8gb modules.
lrwxrwxrwx 1 root root 38 Mar 28 03:54 /etc/nvpmodel.conf -> /etc/nvpmodel/nvpmodel_p3767_0003.conf
i2cDumps appear to be the same…
Dev kit Nano Orin 8gb
We try with Production Orin Nano 8gb modules and nvpmodel is correct. Please re-flash with the initrd command and check again.
Thanks for looking into this. I have to apologize as there has been some things found on my end that was causing issues with linking the correct nvpmodel.conf Primarily the use of a custom dtb + extlinux.conf. that was designed for 16gb orin nx.
Apologies for the waste and thank you for great support.
