Nvpmodel not working, and power configs not being honored
I’ve flashed my orin-nx-8gb with the following command
./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
  -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" \
  --showlogs --network usb0 p3509-a02+p3767-0000 internal
but now I can’t control the power mode of this device. The nvpmodel conf file is wrong and maps to a orin-nx-16gb instead of a orin-nx-8gb and when I try to set it manually the cores I want active those configs are not honored
I’ve attached the dmesg output of this board
any help will be appreciated in trying to figure out what is going on
failednvpmodel_dmesg.zip (19.0 KB)
If I remember correctly, new BSP version have fixed this issue. Please upgrade.
I’m currently using jetpack 5.1.1
Do I need to update to jetpack 6.0 or updating to the latest 5 is enough?
I tried reading through the release notes, but I can’t seem to find anything related to this topic
Thanks again for the support
latest jp5 should be sufficient.
