Hi ,
I’m using Orin NX 16GB and Jetpack on custom board.
Instead of GUI, I want to set power mode to 10W in terminal.
is it possible?
I’m wondering if the above settings still apply or reset after reboot.
Also, I would like to know how to set it up permanently if it is reset.
Run
sudo nvpmodel -m <# of power mode>
You can check /etc/nvpmodel.conf for available power modes.
YES.
Thank you for your quick response.
I have more questions.
Does power mode mean MAX power?
If it means MAX power, does it not exceed this value at boot time?
Or from when does the power mode apply after the board starts booting?
I mean you should check /etc/nvpmodel.conf for what power mode you want to set.
MAXN is just one of them.
If I set 10W, does max power not exceed 10w no matter what app I run?
As I asked above, I wonder when the power mode is applied after the power is applied.
It’s only an approximation.
I don’t think it’s guaranteed that the total power comsumption will always not exceed the limit.
If it doesn’t involve enabling/disabling addtional CPU cores, then it takes effect immediately;
it it does, reboot is required for the new power mode to apply.
I’m not sure what this part means.
If I don’t touch the core settings other than the power mode during the boot process, does that mean that the power mode I pre-set will be applied immediately?
For example, this is the power mode config on my AGX Orin:
# MAXN is the NONE power model to release all constraints
< POWER_MODEL ID=0 NAME=MAXN >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 1
CPU_ONLINE CORE_5 1
CPU_ONLINE CORE_6 1
CPU_ONLINE CORE_7 1
CPU_ONLINE CORE_8 1
CPU_ONLINE CORE_9 1
CPU_ONLINE CORE_10 1
CPU_ONLINE CORE_11 1
TPC_POWER_GATING TPC_PG_MASK 0
GPU_POWER_CONTROL_ENABLE GPU_PWR_CNTL_EN on
CPU_A78_0 MIN_FREQ 729600
CPU_A78_0 MAX_FREQ -1
CPU_A78_1 MIN_FREQ 729600
CPU_A78_1 MAX_FREQ -1
CPU_A78_2 MIN_FREQ 729600
CPU_A78_2 MAX_FREQ -1
GPU MIN_FREQ 0
GPU MAX_FREQ -1
GPU_POWER_CONTROL_DISABLE GPU_PWR_CNTL_DIS auto
EMC MAX_FREQ -1
DLA0_CORE MAX_FREQ -1
DLA1_CORE MAX_FREQ -1
DLA0_FALCON MAX_FREQ -1
DLA1_FALCON MAX_FREQ -1
PVA0_VPS MAX_FREQ -1
PVA0_AXI MAX_FREQ -1
< POWER_MODEL ID=1 NAME=MODE_15W >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 0
CPU_ONLINE CORE_5 0
CPU_ONLINE CORE_6 0
CPU_ONLINE CORE_7 0
CPU_ONLINE CORE_8 0
CPU_ONLINE CORE_9 0
CPU_ONLINE CORE_10 0
CPU_ONLINE CORE_11 0
TPC_POWER_GATING TPC_PG_MASK 248
CPU_A78_0 MAX_FREQ 1113600
GPU MIN_FREQ 0
GPU MAX_FREQ 408000000
EMC MAX_FREQ 2133000000
DLA0_CORE MAX_FREQ 614400000
DLA1_CORE MAX_FREQ 614400000
DLA0_FALCON MAX_FREQ 294400000
DLA1_FALCON MAX_FREQ 294400000
PVA0_VPS MAX_FREQ 307200000
PVA0_AXI MAX_FREQ 217600000
< POWER_MODEL ID=2 NAME=MODE_30W >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 1
CPU_ONLINE CORE_5 1
CPU_ONLINE CORE_6 1
CPU_ONLINE CORE_7 1
CPU_ONLINE CORE_8 0
CPU_ONLINE CORE_9 0
TPC_POWER_GATING TPC_PG_MASK 240
CPU_A78_0 MAX_FREQ 1728000
CPU_A78_1 MAX_FREQ 1728000
GPU MIN_FREQ 0# MAXN is the NONE power model to release all constraints
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 1
CPU_ONLINE CORE_5 1
CPU_ONLINE CORE_6 1
CPU_ONLINE CORE_7 1
CPU_ONLINE CORE_8 1
CPU_ONLINE CORE_9 1
GPU MIN_FREQ 0
GPU MAX_FREQ -1
EMC MAX_FREQ -1
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 0
CPU_ONLINE CORE_5 0
CPU_ONLINE CORE_6 0
CPU_ONLINE CORE_7 0
CPU_ONLINE CORE_8 0
CPU_ONLINE CORE_9 0
GPU MIN_FREQ 0
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 1
CPU_ONLINE CORE_5 1
CPU_ONLINE CORE_6 1
CPU_ONLINE CORE_7 1
CPU_ONLINE CORE_8 0
CPU_ONLINE CORE_9 0
GPU MIN_FREQ 0
GPU MAX_FREQ 612000000
EMC MAX_FREQ -1
DLA0_CORE MAX_FREQ 1369600000
DLA1_CORE MAX_FREQ 1369600000
DLA0_FALCON MAX_FREQ 729600000
DLA1_FALCON MAX_FREQ 729600000
PVA0_VPS MAX_FREQ 512000000
PVA0_AXI MAX_FREQ 358400000
< POWER_MODEL ID=3 NAME=MODE_50W >
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 1
CPU_ONLINE CORE_5 1
CPU_ONLINE CORE_6 1
CPU_ONLINE CORE_7 1
CPU_ONLINE CORE_8 1
CPU_ONLINE CORE_9 1
CPU_A78_0 MAX_FREQ 1497600
CPU_A78_1 MAX_FREQ 1497600
CPU_A78_2 MAX_FREQ 1497600
GPU MIN_FREQ 0
GPU MAX_FREQ 816000000
EMC MAX_FREQ -1
PVA0_VPS MAX_FREQ 704000000
PVA0_AXI MAX_FREQ 486400000
# mandatory section to configure the default power mode
< PM_CONFIG DEFAULT=2 >
EMC MAX_FREQ -1
CPU_ONLINE CORE_0 1
CPU_ONLINE CORE_1 1
CPU_ONLINE CORE_2 1
CPU_ONLINE CORE_3 1
CPU_ONLINE CORE_4 1
CPU_ONLINE CORE_5 1
CPU_ONLINE CORE_6 1
CPU_ONLINE CORE_7 1
CPU_ONLINE CORE_8 1
CPU_ONLINE CORE_9 1
GPU MIN_FREQ 0
EMC MAX_FREQ -1
CPU_ONLINE CORE_X 0 means this CPU core is disabled and is not visible to the system.
Like if you are now at mode 0 (MAXN), where all 12 cores are enabled, and you want to switch to mode 2 (30W), in which core 8, 9, 10, 11 are disabled, then reboot is required; but if you switch to mode 3 (50W), there is no change in enabling/disabling any CPU cores, so it takes effect immediately and you don’t need to reboot the device.
Oh! I understand what you mean.
However, I am experiencing one problem and need debugging.
Despite setting it to 10W and rebooting it multiple times, the situation continues to soar to 16-19w during the boot process.
This is why I kept asking when the power mode was applied during the booting process.
I’ll test this part a little bit more.
Thank you.
ghw_dsg:
CPU cores are only disabled after it boots into the Linux kernel, and they are all enabled in earlier bootloader stages.
It is expected that the device will consume more power during boot as it performs self hardware check, so every hardware component will be triggered, hence higher power comsumption. The same goes for an x86 PC.
