Disable apt upgrade
Hello NV Teams
Currently, on our self-developed carrier board, some customers have encountered issues where using “sudo apt upgrade” causes the system to fail to start due to driver changes. I would like to know if there is any way to completely disable this feature.
For information, please share which Jetpack version you are using.
Thank you for your reply. Now I want to disable it for each version.
Please run the script to install packages matching with Jetpack version:
Making sure you're not a bot!
So now let’s use 36.4.3. How can I completely disable the apt upgrade function?
On r36.4.3, please do
[Jetpack 6.1/r36.4.0] Self-built kernel is overwritten after sudo apt update && sudo apt upgrade
