Hey,
I’m trying to figure out how to debug an issue I’m having implementing DXR into my project. Here is the code for reference(it’s basically just a copy and paste from the Microsoft DXR example project). The issue is simple: I’m getting all black in the render target. It’s my understanding that the miss shader should be called, even if the rays don’t hit any geometry. In that case I should be getting a blue color buffer. Any ideas on what I might be doing wrong, or ways I can debug this issue?
void DXR_DoRaytracing(int width, int height, DXRMesh &mesh, D3DBuffer &m_indexBuffer, SceneConstantBuffer &m_sceneCB)
	auto commandList = m_deviceResources->GetCommandList();
	auto frameIndex = m_deviceResources->GetCurrentFrameIndex();
	auto DispatchRays = [&](auto* commandList, auto* stateObject, auto* dispatchDesc)
		// Since each shader table has only one shader record, the stride is same as the size.
		dispatchDesc->HitGroupTable.StartAddress = d3d12CoreState->m_hitGroupShaderTable->GetGPUVirtualAddress();
		dispatchDesc->HitGroupTable.SizeInBytes = d3d12CoreState->m_hitGroupShaderTable->GetDesc().Width;
		dispatchDesc->HitGroupTable.StrideInBytes = dispatchDesc->HitGroupTable.SizeInBytes;
		dispatchDesc->MissShaderTable.StartAddress = d3d12CoreState->m_missShaderTable->GetGPUVirtualAddress();
		dispatchDesc->MissShaderTable.SizeInBytes = d3d12CoreState->m_missShaderTable->GetDesc().Width;
		dispatchDesc->MissShaderTable.StrideInBytes = dispatchDesc->MissShaderTable.SizeInBytes;
		dispatchDesc->RayGenerationShaderRecord.StartAddress = d3d12CoreState->m_rayGenShaderTable->GetGPUVirtualAddress();
		dispatchDesc->RayGenerationShaderRecord.SizeInBytes = d3d12CoreState->m_rayGenShaderTable->GetDesc().Width;
		dispatchDesc->Width = width;
		dispatchDesc->Height = height;
		commandList->DispatchRays(stateObject, dispatchDesc);
	auto SetCommonPipelineState = [&](auto* descriptorSetCommandList)
		descriptorSetCommandList->SetDescriptorHeaps(1, d3d12CoreState->m_descriptorHeap.GetAddressOf());
		// Set index and successive vertex buffer decriptor tables
		commandList->SetComputeRootDescriptorTable(GlobalRootSignatureParams::VertexBuffersSlot, m_indexBuffer.gpuDescriptorHandle);
		commandList->SetComputeRootDescriptorTable(GlobalRootSignatureParams::OutputViewSlot, d3d12CoreState->m_raytracingOutputResourceUAVGpuDescriptor);
	commandList->SetComputeRootSignature(d3d12CoreState->m_raytracingGlobalRootSignature.Get());
	// Copy the updated scene constant buffer to GPU.
	memcpy(&d3d12CoreState->m_mappedConstantData[frameIndex].constants, &m_sceneCB, sizeof(m_sceneCB));
	auto cbGpuAddress = d3d12CoreState->m_perFrameConstants->GetGPUVirtualAddress() + frameIndex * sizeof(d3d12CoreState->m_mappedConstantData[0]);
	commandList->SetComputeRootConstantBufferView(GlobalRootSignatureParams::SceneConstantSlot, cbGpuAddress);
		D3D12_DISPATCH_RAYS_DESC dispatchDesc = {};
		SetCommonPipelineState(commandList);
		commandList->SetComputeRootShaderResourceView(GlobalRootSignatureParams::AccelerationStructureSlot, mesh.m_topLevelAccelerationStructure->GetGPUVirtualAddress());
		DispatchRays(d3d12CoreState->m_dxrCommandList.Get(), d3d12CoreState->m_dxrStateObject.Get(), &dispatchDesc);
		auto renderTarget = m_deviceResources->GetRenderTarget();
		D3D12_RESOURCE_BARRIER preCopyBarriers[2];
		preCopyBarriers[0] = CD3DX12_RESOURCE_BARRIER::Transition(renderTarget, D3D12_RESOURCE_STATE_RENDER_TARGET, D3D12_RESOURCE_STATE_COPY_DEST);
		preCopyBarriers[1] = CD3DX12_RESOURCE_BARRIER::Transition(d3d12CoreState->m_raytracingOutput.Get(), D3D12_RESOURCE_STATE_UNORDERED_ACCESS, D3D12_RESOURCE_STATE_COPY_SOURCE);
		commandList->ResourceBarrier(ARRAYSIZE(preCopyBarriers), preCopyBarriers);
		commandList->CopyResource(renderTarget, d3d12CoreState->m_raytracingOutput.Get());
		D3D12_RESOURCE_BARRIER postCopyBarriers[2];
		postCopyBarriers[0] = CD3DX12_RESOURCE_BARRIER::Transition(renderTarget, D3D12_RESOURCE_STATE_COPY_DEST, D3D12_RESOURCE_STATE_PRESENT);
		postCopyBarriers[1] = CD3DX12_RESOURCE_BARRIER::Transition(d3d12CoreState->m_raytracingOutput.Get(), D3D12_RESOURCE_STATE_COPY_SOURCE, D3D12_RESOURCE_STATE_UNORDERED_ACCESS);
		commandList->ResourceBarrier(ARRAYSIZE(postCopyBarriers), postCopyBarriers);
