but the DP of a Zotac GTX 460 (and other cards, I tested with DPs) works fine.
I replaced a GTX 460 with a GTX 760 only to find out, that the DP (DFP-4) doesn’t work on the 760 with the current G03 driver. I use a multi monitor setup (30" @DFP-3 and 24" @DFP-4), and due to a DVI based console switch on the 24", I have to use the DP connector on this monitor…
When booting the GTX 760 with only the 24" attached to the DP, boot messages appear on it, but X startup fails, because no monitor is detected. When booting in dual monitor setup, the second screen (24" on DP) isn’t detected as well.
Neither the GTX 460 nor a AMD HD7770 suffer from this issue, but I need to return the 460 to the owner, and the HD 7770 suffers from other issues.
OS: openSUSE 13.1.
nvidia-bug-report.log.gz (210 KB)
