Display Port MST Hub support
Hi!
I have gone through many topics, but I’m still unsure if there is general support for DP1.2 MST Hubs on the Jetson AGX Orin Developer kit. I have seen that daisy-chaining capable monitors can work, but I would like to confirm if products like:
  1. https://www.aten.com/global/en/products/professional-audiovideo/video-splitters/vs92dp/
  2. Aten VS192 2-Port 4K DisplayPort Splitter / MST-Hub - KVM-Switch Versand
can replace the daisy-chain setup. Using such devices would be much easier for me.
Another question I have is whether these devices support the use of DP to HDMI adapters on the outputs, or if I need to stick with Display Port outputs.
  1. We only validated the daisy chain setup.
  2. Yes, you have to use DP outputs.
