Used rpmfusion nvidiahowto for driver installation and had this issue. Also tried this guide Fedora 36/35/34 NVIDIA [515.65.01 / 510.85.02 / 470.141.03 / 390.154 / 340.108] Drivers Install Guide – If Not True Then False and resulting the opposite effects. No Laptop or HDMI output and only Displayport. Deleted /etc/X11/xorg.conf and the issue reverted back. In the display settings I can see all screens connected, but when I try to enable the DP monitor, the screen flickers, stays black and reverts to the off state.
nvidia-bug-report.log.gz (1.3 MB)
Fedora34, Gnome40, Xorgx11 and nvidia 465.27, also tried 460.80 and 460.67
Probably doing something wrong(Linux Newbie)
Tried doing startx – -logverbose 6 but crashes.
These pictures show my current problem :
I have this same setup when I run windows with no Issues. Also, the Samsung G9 is connected with HDMI and the Asus PG35VQ is connected with DP. This same setup also works with Wayland and noveau installed. Hope any of this info helps! Thank you!
