DLSS and UE5.7 volumetric fog Bug
Compatibility issues between DLSS and volumetric fog.
The problem resolves itself when either DLSS or volumetric fog is turned off.
Test.zip
/Script/Engine.World’/Game/Dof_Test.Dof_Test’
Welcome @344141 to the NVIDIA developer forums!
I could not safely access the server you linked to for file download. Could you try and upload the ZIP file here please?
Also, you called this file “DoF_Test”, is Depth of Field also interacting here?
Uploading files larger than 100MB is very difficult. Neither split ZIP archives nor split RAR archives can be uploaded properly because the file extensions are not allowed. Therefore, I have uploaded Test.part1.zip and Test.part2.zip—their original names were .rar files. So, if you cannot extract them, please try changing the extensions back to .rar.
You’re very observant. It should actually be named DLSS_Test. “Depth of Field” was my mistake, and I don’t believe it’s related to the issue.
If everything goes smoothly, after opening the project and loading the level (Dof_Test), you should be able to reproduce the issue.
Test.part1.zip (80 MB)
Test.part2.zip (38.4 MB)
Thanks for uploading!
I will check it and very likely create an internal issue to track it. Due to the upcoming holidays I might not reply very soon. So please be patient.
I’ve been looking forward to your reply.
