Without installer.sh I suppose it is possible for X to run using Nouveau video driver…especially in console mode. Otherwise it is very doubtful graphics would work. The installer.sh script adds the accelerated hardware access files…including video driver. Consider that many people want to use the GPU acceleration…this requires those files, it is part of the GPU/video driver (CUDA and desktop video both use GPU…framebuffers can display video without direct hardware access, GPU computation in general cannot).
This command will tell you if the files are in place which are required for correct hardware function:
