Do not manage to activate HDMI on a laptop with NVIDIA GeForce RTX 2060
I am trying to use the HDMI output on my laptop (MSI GL63 8SE) with Debian 10, the problem that it’s not detecting my monitor in HDMI port. I have two VGA compatible controllers, which is Intel UHD Graphics 630 and NVIDIA GeForce RTX 2060.
lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 630 (Mobile)
01:00.0 VGA compatible controller: NVIDIA Corporation TU106M [GeForce RTX 2060 Mobile] (rev a1)
After some searching, I found out this should be some settings related to Nvidia optimus technology.
https://unix.stackexchange.com/questions/321151/do-not-manage-to-activate-hdmi-on-a-laptop-that-has-optimus-bumblebee
According to the answer, I installed bumblebee by the following instruction
sudo apt-get install bumblebee-nvidia primus libgl1-nvidia-glx
After that, I created a 20-intel.conf file in the Xorg configuration directory (/usr/share/X11/xorg.conf.d)
Section "Device"
    Identifier "intelgpu0"
    Driver "intel"
    Option "VirtualHeads" "2"
EndSection
And modified /etc/bumblebee/xorg.conf.nvidia as below
Section "ServerLayout"
    Identifier  "Layout0"
    Option      "AutoAddDevices" "true"
    Option      "AutoAddGPU" "false"
EndSection
Section "Device"
    Identifier  "DiscreteNvidia"
    Driver      "nvidia"
    VendorName  "NVIDIA Corporation"
    Option "ProbeAllGpus" "false"
    Option "NoLogo" "true"
    Option "AllowEmptyInitialConfiguration"
EndSection
Section "Screen"
    Identifier "Screen0"
    Device "DiscreteNVidia"
EndSection
However, with previous configuration and starting intel-virtual-output, I could not output the signal to my external monitor by HDMI.
xrandr --listproviders
Providers: number : 1
Provider 0: id: 0x47 cap: 0xb, Source Output, Sink Output, Sink Offload crtcs: 5 outputs: 3 associated providers: 0 name:Intel
Any suggestions? Thank you!
nvidia-bug-report.log.gz (1.1 MB)
I’d rather suggest to use PRIME rather than bumblebee, the primus bridge also doesn’t work anymore with drivers >418. See this for a quick howto:
[url]https://devtalk.nvidia.com/default/topic/1022670/linux/official-driver-384-59-with-geforce-1050m-doesn-t-work-on-opensuse-tumbleweed-kde/post/5203910/#5203910[/url]
Please uninstall bumblebee beforehand.
