Hello, after installing DOCA on the BlueField-2, I encountered an error while trying to perform a firmware update, so I first checked whether this model is supported. I searched through various DOCA versions, but I couldn’t find MT_0000000809 among the supported BlueField-2 models. Should I consider purchasing a new DPU?
Don’t worry about it,the DOCA support all versions of bluefield devices (include es)
Based on the PSID you shared, it appears this is an engineering sample, which would explain why it’s not on the website.
As replied above, DOCA should support all BlueField-2 models regardless, so the errors might not be related to DOCA.
If you are still encountering an issue, please open a case with enterprisesupport@nvidia.com, and it will be handled based on entitlement.
Thanks,
Jonathan.
Thank you for your answers. I will try the installation process again from the beginning. Thanks!
