Docker authorization for Installing Drive OS 7.0.3
DRIVE OS Version: Provide DRIVE OS version. Example: 7.0.3
Issue Description: Provide issue description and attached logs as text message instead of images
Hello, I’m trying to install DRIVE 7.0.3 as below instruction
But it failed.
What is the problem?
Dear @MDS_Eddy ,
Could you please use text message instead of picture in posts.
Could you try changing the API key and login again to see if it fixes the issue?
I’ve regenerated new API Key but it has still issue.
nvidia@host2004:~/docker_space$
nvidia@host2004:~/docker_space$ docker logout nvcr.io
Removing login credentials for nvcr.io
nvidia@host2004:~/docker_space$ docker login nvcr.io -u '$oauthtoken'
Password:
WARNING! Your credentials are stored unencrypted in '/home/nvidia/.docker/config.json'.
Configure a credential helper to remove this warning. See
https://docs.docker.com/go/credential-store/
Login Succeeded
nvidia@host2004:~/docker_space$ sudo docker pull nvcr.io/drive/driveos-sdk/drive-agx-linux-nsr-aarch64-sdk-build-x86:7.0.3.0-0010
[sudo] password for nvidia:
Error response from daemon: unauthorized: <html>
<head><title>401 Authorization Required</title></head>
<body>
<center><h1>401 Authorization Required</h1></center>
<hr><center>nginx/1.22.1</center>
</body>
</html>
Public docker images are fine.
nvidia@host2004:~/docker_space$ sudo docker pull nvcr.io/nvidia/pytorch:25.11-py3-igpu       25.11-py3-igpu: Pulling from nvidia/pytorch
b8a35db46e38: Pulling fs layer
f6716418f767: Pulling fs layer
4f4fb700ef54: Pulling fs layer
a37632b88fc3: Pulling fs layer
764ab5736900: Pulling fs layer
bb12ff708c82: Pulling fs layer
f3ac4be1e966: Pulling fs layer
106d8e09a61f: Pull complete
2eab8b813d8a: Pull complete
8b5255968c0d: Pull complete
a43e5864aee0: Pull complete
27e0614651cc: Pull complete
174ae2c66139: Pull complete
8cd8e922f7a6: Pull complete
a649f6fcbd94: Pull complete
25fc3abdd9ca: Pull complete
4a2456bef924: Pull complete
d8c5eb8b9c6d: Pull complete
0c58d514981b: Pull complete
203d0cb70263: Pull complete
e90c40d4ff0d: Pull complete
f2c3f6e205bb: Pull complete
b8dcc28f9470: Pull complete
da733abd0ef5: Pull complete
74541aa1a71f: Pull complete
671b6bd0dfff: Pull complete
2c18615dacc8: Pull complete
7d2d12d15a8a: Pull complete
ee095bf00a47: Pull complete
ce20b04e5ea8: Pull complete
eff421e68a89: Pull complete
a00c3fc4be4c: Pull complete
b0cf830b7a0c: Pull complete
3dc74527e2ed: Pull complete
fd357a7aadf0: Pull complete
693f9ec60c6f: Pull complete
9661129fe9a6: Pull complete
f2a54435f872: Pull complete
bc63d46259d2: Pull complete
327d0b06b31d: Pull complete
c699b163c870: Pull complete
0a3bb5527163: Pull complete
8a32a5f82af9: Pull complete
b4199ef13a43: Pull complete
f49a7030122c: Pull complete
f0f6d360937d: Pull complete
9d65fefc582e: Pull complete
10203ef8ac6a: Pull complete
7bdf4457063b: Pull complete
ab400c7104dd: Pull complete
c41e94c44306: Pull complete
efc50e873566: Pull complete
77849df76f60: Pull complete
6121cf128cf1: Pull complete
9808ee963aee: Pull complete
d089a2a4591e: Pull complete
66aff795a167: Pull complete
e7b20ab8b374: Pull complete
38059466714b: Pull complete
6424071bdc10: Pull complete
Digest: sha256:7826df58d47f2c2584fb08e394ee11b43a411812fedaa41f41bdfd79ffc70eec
Status: Downloaded newer image for nvcr.io/nvidia/pytorch:25.11-py3-igpu
It is working with the other host system, it is Ubuntu 22.04.
Dear @MDS_Eddy ,
I don’t see issue with ubuntu 20.04 . Is it ok to use your ubuntu 22.04(your working machine) host to continue flash?
Also, please check
  1. Check downloading DRIVE OS 6.0.10 docker container to see if it also has issue.
  2. Try another ubuntu 20.04 machine to confirm if issue is specific to current ubuntu 20.04 host.
Yes, It sholud be not a problem version of ubuntu directly.
The first system has a problem with “sudo apt install docker.io”
So, I’ve installed docker via other debian packages what those are “docker-ce docker-ce-cli containerd.io docker-compose-plugin”
And I regenerated gpg key
Maybe, it makes difference.
Ok. Can we close the issue?
Yes, It can be
