JetPack 7.1 is released today, When will the docker image available on ngc? Need to run it on Thor. Thanks.
What kind of container do you need?
There are several containers (ex., vLLM) that can run on JetPack 7.1.
Same question here. None of the base images seem to support Jetpack 7.1 / l4t r38 yet.
- l4t-tensorrt, latest tag is
r10.3.0-develbut we need 10.13.3.9 - l4t-jetpack latest tag is
r36.4.0, we need at r38.4 - l4t-base latest tag is
r36.2.0, we need r38.4
On this webpage click Tags https://catalog.ngc.nvidia.com/orgs/nvidia/containers/cuda
If still on cuda-13.0 scroll down a bunch to see the cuda-13.0.2 Ubuntu 24.04 images. Pick the one with the features you need. It is arm64 and for me works on Thor r38.4.0 Jetpack 7.1. It also works well as a base image in Dockerfile.
run container with --runtime nvidia
On this webpage for Tensorrt docker image pick the ubuntu 24.04 with the version of Tensorrt you want.https://docs.nvidia.com/deeplearning/frameworks/container-release-notes/
Then go here to get the path. https://catalog.ngc.nvidia.com/orgs/nvidia/containers/tensorrt
root@chithor:/# cat /etc/nv_tegra_release
# R38 (release), REVISION: 4.0, GCID: 43443517, BOARD: generic, EABI: aarch64, DATE: Wed Dec 31 00:15:19 UTC 2025
# KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
INSTALL_TYPE=openrm
root@chithor:/# cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=24.04
DISTRIB_CODENAME=noble
DISTRIB_DESCRIPTION="Ubuntu 24.04.3 LTS"
ngc registry image info nvcr.io/nvidia/cuda:13.0.2-runtime-ubuntu24.04
Image Information
Architecture: arm64
Image Size: 1.65 GB
Digest: sha256:bbfc230dfd4c3bb2eadacdc22cb7e2ea3453e93bb3ee40e241357eb0bcd5c6a6
Schema Version: 1
Signed?: True
Last Updated: Nov 06, 2025
Our internal team is discussing this request.
Will share more information with you later.
There are some DLFW containers available.
Please use them instead:
vLLM: https://catalog.ngc.nvidia.com/orgs/nvidia/containers/vllm?version=26.01-py3
SGLang: SGLang | NVIDIA NGC
