Docker issue
Hi all,
I was testing nvidia-docker on TX2 with JetPack v4.3. My final goal is to implement Triton inference client on this device.
So what I did a small testing is this command below.
Command:
docker run --rm --gpus all nvcr.io/nvidia/tensorrtserver:19.10-py3 nvidia-smi
Output:
docker: Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?.
See 'docker run --help'.
Is there any suggestions about this issue?
Thank you!
BR,
Chieh
Env Info
  • JetPack v4.3
  • TX2 device
  • ubuntu version: 18.04
  • python3 version: 3.6.9
  • Tensorflow version: 1.15
  • TensorRT version: 6.0.1.10
  • CUDA version: 10.0.326
  • cuDNN version: 7.6.3
  • docker version: Docker version 18.09.7, build 2d0083d
The image doesn’t support TX2 environment.
Currently, we only support l4t-based container for the Jetson device.
Hi AastaLLL,
I see!! Thanks for your information!!
BR,
Chieh
