I’m facing trouble using nvidia-docker on Jetson TX2. In particular, when I run the example I receive the following output:
dp@nvidia-jetson-tx2:~$ sudo docker run --runtime nvidia --network host -it -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/l4t-base:r32.3.1
Unable to find image 'nvcr.io/nvidia/l4t-base:r32.3.1' locally
r32.3.1: Pulling from nvidia/l4t-base
8aaa03d29a6e: Pull complete
e73d3a974854: Pull complete
2c14cdba18f5: Pull complete
23dd63c7659b: Pull complete
3bd414bd9504: Pull complete
cafd526eb263: Pull complete
483b0873e636: Pull complete
2568c5428ff2: Pull complete
6bcd9356d42f: Pull complete
c7f6d0180a4e: Pull complete
beddc9b83fb0: Pull complete
656f2307c79e: Pull complete
fe2e73a571b7: Pull complete
f5decba41c07: Pull complete
f0b6e413c48c: Pull complete
Digest: sha256:e8987d52ddb9496948e02656fc62d46561abce25bfe83203f4bc24c67e094578
Status: Downloaded newer image for nvcr.io/nvidia/l4t-base:r32.3.1
docker: Error response from daemon: OCI runtime create failed: container_linux.go:349: starting container process caused "process_linux.go:449: container init caused \"process_linux.go:432: running prestart hook 0 caused \\\"error running hook: exit status 1, stdout: , stderr: exec command: [/usr/bin/nvidia-container-cli --load-kmods configure --ldconfig=@/sbin/ldconfig.real --device=all --compute --compat32 --graphics --utility --video --display --pid=19059 /var/lib/docker/overlay2/91ff2e1868519c3034feacf27a61ca96c93f7c0356273040febfad9c3c69c284/merged]\\\\nnvidia-container-cli: initialization error: cuda error: unknown error\\\\n\\\"\"": unknown.
ERRO[0083] error waiting for container: context canceled
I have checked the Troubleshooting section , but I seem to have all the necessary libraries installed.
As a side note, the device query example from CUDA also seems to not be working:
dp@nvidia-jetson-tx2:~$ ./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 30
-> unknown error
Result = FAIL
Which JetPack version do you use?
Please use JetPack4.3 for nvcr.io/nvidia/l4t-base:r32.3.1 to ensure compatibility.
dpdani
May 19, 2020, 12:24pm
4
How do I check which JetPack version I’m running?
Returns this:
NVIDIA Jetson TX2
L4T 32.3.1 [ JetPack 4.3 ]
Ubuntu 18.04.4 LTS
Kernel Version: 4.9.140-tegra
CUDA NOT_INSTALLED
Although it says that CUDA is not installed, sudo dpkg --get-selections | grep nvidia, yeilds:
libnvidia-compute-435:arm64 install
libnvidia-container-tools install
libnvidia-container0:arm64 install
nvidia-container-csv-cuda install
nvidia-container-csv-cudnn deinstall
nvidia-container-csv-tensorrt deinstall
nvidia-container-csv-visionworks install
nvidia-container-runtime install
nvidia-container-toolkit install
nvidia-docker2 install
nvidia-l4t-3d-core install
nvidia-l4t-apt-source install
nvidia-l4t-bootloader install
nvidia-l4t-camera install
nvidia-l4t-ccp-t186ref install
nvidia-l4t-configs install
nvidia-l4t-core install
nvidia-l4t-cuda install
nvidia-l4t-firmware install
nvidia-l4t-graphics-demos install
nvidia-l4t-gstreamer install
nvidia-l4t-init install
nvidia-l4t-initrd install
nvidia-l4t-jetson-io install
nvidia-l4t-kernel install
nvidia-l4t-kernel-dtbs install
nvidia-l4t-kernel-headers install
nvidia-l4t-multimedia install
nvidia-l4t-multimedia-utils install
nvidia-l4t-oem-config install
nvidia-l4t-tools install
nvidia-l4t-wayland install
nvidia-l4t-weston install
nvidia-l4t-x11 install
nvidia-l4t-xusb-firmware install
In particular, I’ve read the code and it looks like it’s referencing folder /usr/local/cuda/, while my CUDA installation appears to be in /usr/local/cuda-10.0/.
Thanks for the environment information.
We will try to reproduce this and update more information with you later.
Sorry for keeping you waiting.
Since we have released a newer package, would you mind to try our JetPack4.4 first?
dpdani
June 3, 2020, 3:02pm
10
I’m having issues upgrading, I think everything is fine until I get this:
dpkg: error processing archive /var/cache/apt/archives/nvidia-l4t-cuda_32.4.2-20200408182620_arm64.deb (--unpack):
trying to overwrite '/usr/lib/aarch64-linux-gnu/libcuda.so', which is also in package libnvidia-compute-435:arm64 435.17.01-0ubuntu1
You will need to reflash and install the packages all from the JetPack4.4.
Please reflashed the system first.
