Is it possible to run nvidia/tensorrt containers on Jetson machines? It should be possible, if you follow NVIDIA Container Runtime on Jetson .
I want to do this so that the development environment (Docker running on macOS, windows, linux) is similar to the deployment environment (Jetson). Unfortunately, my application is crashing with pycuda._driver.Error: cuInit failed: unknown error
when my application (and the python repl) initializes cuda with:
import pycuda.driver as cuda
cuda.init()
In this case, I am not setting the runtime: nvidia
. When I do that, I get a different error: https://github.com/NVIDIA/nvidia-docker/issues/1598
I’m wondering if there are fundamental reasons this is happening.
Unfortunately, I cannot run l4t-base, l4t-cuda or l4t-tensorrt on my development machine because they don’t support multiple architectures. See TensorRT L4T docker image Python version Issue - #17 by mdegans for good reasons why we should have this.
Sorry for the late reply.
May I know how do you set up the Jetson first?
Do you use JetPack4.6? If not, would mind giving it a try?
Hey @AastaLLL ,
I’m using Jetpack 4.5.1. I don’t think there is anything that would be solved by upgrading to Jetpack 4.6.
Please give it a try.
It will need JetPack4.6 for some compatibility issues.
The container is built on the top of l4t-cuda
and you can find this constraint in its document as below:
https://catalog.ngc.nvidia.com/orgs/nvidia/containers/l4t-cuda
The image is tagged with the version corresponding to the CUDA release version. Based on this, the l4t-cuda:r10.2.460-runtime container is intended to be run on devices running JetPack 4.6 which supports CUDA version 10.2.460
I just upgraded to 4.6, but unfortunately now docker fails to start, even after reinstalling it.
I get the same issue as: Docker error "failed to mount overlay: no such device" storage-driver=overlay2
Running sudo dockerd
gets me:
failed to mount overlay: no such device storage-driver=overlay2
The full output:
INFO[2022-02-23T16:33:53.976453799+01:00] Starting up
WARN[2022-02-23T16:33:53.976690154+01:00] Running experimental build
INFO[2022-02-23T16:33:53.980197780+01:00] parsed scheme: "unix" module=grpc
INFO[2022-02-23T16:33:53.980279381+01:00] scheme "unix" not registered, fallback to default scheme module=grpc
INFO[2022-02-23T16:33:53.980365590+01:00] ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock <nil> 0 <nil>}] <nil> <nil>} module=grpc
INFO[2022-02-23T16:33:53.980404663+01:00] ClientConn switching balancer to "pick_first" module=grpc
INFO[2022-02-23T16:33:53.983147128+01:00] parsed scheme: "unix" module=grpc
INFO[2022-02-23T16:33:53.983230809+01:00] scheme "unix" not registered, fallback to default scheme module=grpc
INFO[2022-02-23T16:33:53.983292538+01:00] ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock <nil> 0 <nil>}] <nil> <nil>} module=grpc
INFO[2022-02-23T16:33:53.983329338+01:00] ClientConn switching balancer to "pick_first" module=grpc
ERRO[2022-02-23T16:33:53.990005739+01:00] failed to mount overlay: no such device storage-driver=overlay2
ERRO[2022-02-23T16:33:53.990079980+01:00] [graphdriver] prior storage driver overlay2 failed: driver not supported
failed to start daemon: error initializing graphdriver: driver not supported
system
closed
March 9, 2022, 3:33pm
#8
